WD Raptor for OS
snicka
WD Raptor for OS
Post by snicka »
I just purchased a Western Digital 74GB Raptor HD that I want to use as my OS drive.
I currently use the drive that came with my Dual 2.3GHz G5 for the OS drive.
What is the best way to install the new drive?
Should I pull the current OS drive, attach the new drive, boot from CD and format & install? Or is there a better way?
Thanks.
westla
Post by westla »
In my humble opinion that's overkill for the system drive. Do you have a Raptor as your audio drive? If not use it for that.
I don't think you'll get that much improvement with a 10K drive for your system.
just my $.02
snicka
Post by snicka »
Really?
Is that the general consensus? Anyone else care to chime in?
I do not have a Raptor for my audio drive, but a 7200 RPM SATA drive.
Thanks.
WKWizard
Post by WKWizard »
Actually, I believe a 10,000rpm system drive is a good thing. It won't be a huge improvement, but things should seem a bit snappier. A clean install is always good, but if your system is stable then maybe you'd want to use the disk copy utility.
giles117
Post by giles117 »
I agree with westla it is better as an audio drive. When tracking or mixing the System drive gets WAY less action than the audio drive.
DP 6.02
Quad 3.0 Ghz, 8.0 GB RAM, 2 - 1TB HD, 5 - 500GB HD's (RAID)
MOTU HD192, 2408mk3, Microlite, UAD-1, UAD-2, Powercore, Lavry Blue AD/DA convertor, LA-610
Euphonix MC Control
29 years in this business and counting.....Loving every minute of it.....
