Should I install DP4.61 agian?
Posted: Thu Nov 10, 2005 9:46 pm
by afak
Original post: 4.6.1 killed my MIDI???
http://www.unicornation.com/phpBB2/viewtopic.php?t=8020
I just did a clean install of tiger10.4.3 and reinstalled everything expect DP. Everything is working Perfectly (Logic \ Protools \ Peak).
I want to know do you guys think I should install DP again? What are the chance's that it would happen again? I'm scared :lol: and need some advice.
A local college uses DP so the only time I use DP is to transfer stuff to omf and import it to logic.
Use Carbon Copy Cloner first!
Posted: Fri Nov 11, 2005 12:04 am
by zed
Hi Afak,
My suggestion to you is that you first make a copy of everything the way it is before you do the 4.6.1 install. That way, if things go wrong again you can go right back to where you were before.
Just follow this link to read about doing this with CARBON COPY CLONER and to download the software:
http://www.lafcpug.org/tutorials/basic_ ... grade.html
As it happens, I am about to try installing DP 4.6.1 and SampleTank 2.1XL on my new G5 tonight. So I will try to let you know what happens on my end.
Good luck,
Zed
