Hi
I am having some more problems with MSI, in addition to having tuning issues with all instruments as VST.
I have just found out that the bottom ranges of all the pianos are wrong. Once I have corrected for the tuning problem (-1 semi, -30 cent), the MSI pianos are and octave above a normal piano. (ie playing C3 on my MIDI piano plays C4 on MSI piano). I lowered the pitch an octave, so that the notes are in unison with the Clavinova MIDI piano. No problems - until working down the ranges. With the pitch correction in place, I am missing an entire octave of lower range in all the pianos - from A-1 to A0. No output whatsoever - which is extremely frustrating. I am using the same MIDI references as the piano roll in the MOTU booklet (A-1 to C7, C3 as middle C).
What is confusing is that the Steinway preset example by Guillaume Roussel on the MOTU website DEFINITELY uses notes lower than A0. Coupled with the fact that I have not seen anyone else complain about the piano ranges, I assume that MSI pianos do go all the way down to A-1, as on any normal 88 key piano.
Has anyone else had this problem - or could anyone help in finding out what is going on? Without that lower octave, the piano's are virtually useless. I am guessing that this is another VST problem MOTU are having - same thing with the tuning. I hope the 1.1 update fixes all this nonsense up, and that it comes SOON.
Any help or comments would be very much appreciated.
Brian
Piano Ranges problems with VST?
