Is it possible to read the keybinding / commands file
Digiuser
Post by Digiuser »
Is it possible to read/view the keybinding commands file outside of DP?
I need to merge or add a bunch of commands that I am accustomed to having to join the Slate Raven commands.
It would be creat if there was an app or a way to view the keystrokes and associated command names.
Re: Is it possible to read the keybinding / commands file
When I did a lot of edits, I printed the commands window to PDF and copy pasted into a spreadsheet. It's not entirely straightforward but if you have any experience at all with spreadsheets, it's not that difficult. Once you have that you can sort and sift etc, e.g. see everything that is assigned to a character with all the combinations of modifier keys. In my case, it was particularly useful to see everything not assigned.
Digiuser
Post by Digiuser »
Ahhh...that's a solid mid-tech way of going about it.
Thanks for the tip!
dwilliams
Post by dwilliams »
I've already done it. I can post it if there is interest.
Krakadon
aka Dave Williams
Rock, metal, Camas, WA
* 16" M3 Max 16-core 4.05 GHz 48GB 1TB Late 2023 MBP, Sonoma 14.5. TB: UA Apollo QuadFW w/TB card, Satellite OctoTB2 & OctoTB3, PreSonus Quantum 4848 TB2, TB hub w/ USB 3.0 drives; USB 3.0: Softube Console 1 Mk3, Stream Deck XL; USB 2.0: SSL UC1, Fractal Audio Axe-Fx III , Revv Generator 120 MK3; , M Audio Oxygen 49, Akai MPD218, X-Touch U; HDMI: 34" 16:9 & 32" 2K Monitors
* DP 11.32
Digiuser
Post by Digiuser »
I printed mine to a pdf and that worked fine.
What is the method you use?
