Loud clicks from Behringer Wing [Resolved Enough]
Posted: Wed Sep 25, 2024 10:45 am
by dix
I’m in the middle of an installation using an M1 MBP, and a Behringer Wing as the interface. DP is outputting loud intermittent clicks. The Wing doesn’t publish a clock to DP like the I/O in my home studio. “Internal” is the only clocking option in Clock Mode pulldown. Info from the MotuGuru FB page indicates it's not a clocking issue though. Quicktime and QLab playback fine on this same system. Only DP is clicking. Any ideas about this? …or what else the problem may be?
Thx!
Re: Loud clicks from Behringer Wing
Posted: Wed Sep 25, 2024 8:42 pm
by mikehalloran
My gut says check the sample rate and bit depth of your DP projects and check all of the Clock references in the DP manual. I do love searchable pdfs.
Posted: Fri Sep 27, 2024 12:49 pm
by dix
A bad USB connection seems to have been the culprit, but the issue was too intermittent to be certain. We had been using a hub between the MBP and the Wing. Once we found a USB to USB-C cable we never heard the clicks again.
Though the issue gone, I'll leave up the thread as a reminder to people to consider their cabling when stuff like this happens.
