Audio comes out after 20s of playing silence
Posted: Sun Jun 02, 2024 7:21 am
by nickysnd
I have 3 MIDI tracks routed into EW Play instruments. The instruments only come in after 20s of playing silence. For example, if I start playing at the second 15, I begin hearing it at second 35. I have moved the whole sequence 20 seconds, I play from 0:00, and after 20s of silence I can hear it from the beginning. But that's not a solution. I have full licenses on everything, so it's not a "protection" thing.
This is very strange. Is there a DP setting that does that?
Re: Audio comes out after 20s of playing silence
Posted: Fri Jun 28, 2024 5:57 pm
by mikehalloran
nickysnd wrote: Sun Jun 02, 2024 7:21 am I have 3 MIDI tracks routed into EW Play instruments. The instruments only come in after 20s of playing silence. For example, if I start playing at the second 15, I begin hearing it at second 35. I have moved the whole sequence 20 seconds, I play from 0:00, and after 20s of silence I can hear it from the beginning. But that's not a solution. I have full licenses on everything, so it's not a "protection" thing.
Could it be a plug-in issue? If any have "look ahead" functionality, then yes though I've never experienced a 20 second delay. Otherwise, take a look at this thread and see if there's any insight.
viewtopic.php?t=74263
Posted: Fri Jun 28, 2024 6:50 pm
by James Steele
That is strange. Unrelated probably, but your sig says you're on Sonoma 14.4.1? I might suggest going to Sonoma 14.5. It's been pretty good to me and I think it fixed a few things as well.
Posted: Fri Jun 28, 2024 8:00 pm
by HCMarkus
Does this happen with every project or just a specific one?
You might consider reaching out to MOTU.com tech support on this strange one.
Posted: Fri Jun 28, 2024 9:12 pm
by stubbsonic
Are you synching to tap tempo or an external time code source? That's the only time I've ever had that long of a delay with audio playback.
