Dragging a soundbite from the Tracks window crashes DP11.3
Posted: Fri Jan 05, 2024 4:39 pm
Hello,
I am using Revoice Pro 5 and when I drag a soundbite just out of the Tracks window DP 11.3 crashes. It does not even make it to the Revoice window.
This the procedure I am using.
It used to be a video on Youtube now I can't the video but I did download it...
It works when DP does crash from a simple soundbite drag
_________________________________________________
In Revoice set Spot Files to User Timecode
In DP select your Audio soundbites and Set User Timestamp from Sequence
Select a soundbite and drag to Revoice
It is best to drag via the top of the DP window
The soundbites will be positioned at the correct timecode position.
Clicking on the first soundbite in Revoice with the command key pressed will select that soundbite
Press B to display the new press widow.
Then create an APT process.
Press the Shift+ Alt keys and click on the output audio.
Drag the audio into DP
To position at the correct time code select the soundbite and select Move to User Timestamp
You can speed up the workflow by assigning keys to the Timestamp commands in DP
