Page 1 of 6
Sonoma compatibility
Posted: Mon Oct 02, 2023 12:20 am
by SMS
...not great for me. Very slow, menus now require a double-click to open, lots of freezes, requiring force quit.
Re: Sonoma compatibility
Posted: Mon Oct 02, 2023 1:12 am
by James Steele
I have noticed the menu double click. Also the Bounce to Disk dialog doesn't populate with all the options when you first open it and you need to select a format in the dropdown menu again. But as far as speed goes, it seems fine over here.
I hasten to add that you can't blame MOTU on that one. It's what happens when you update and you have older apps that were released a few OSes ago.
Posted: Mon Oct 02, 2023 4:09 am
by SMS
Yes, it’s likely 3rd party plugs or something…
Posted: Mon Oct 02, 2023 8:40 am
by Michael Canavan
It's always a good idea to go through your plugins and update them right before or after updating the OS. It can be a total pain and most definitely older plugins can be responsible for crashes and instability in DP and other DAWs, applications etc.
I have a couple hundred plugins so dozens of different developers, I'm still not 100% through the list, and it's the only time that the new paradigm of apps like Native Access, IK Product Manager and Artturia Software Center is super convenient.
Posted: Mon Oct 02, 2023 9:30 am
by cuttime
At this point, I'd like to know
why I should upgrade to Sonoma. I don't see a lot of compelling reasons at this point to do so. Is it snappier?
Posted: Mon Oct 02, 2023 10:58 am
by gavspen
SMS wrote: ↑Mon Oct 02, 2023 12:20 am
You dont mean all menus, do you? Just DP menus?
FWIW, MOTU says "Digital Performer Version 11
appears to be fully compatible with macOS Sonoma, although final compatibility testing is still on-going" but I assume you've seen that.
Posted: Mon Oct 02, 2023 11:00 am
by SMS
Correct just the menus in DP
Posted: Mon Oct 02, 2023 12:17 pm
by bayswater
cuttime wrote: ↑Mon Oct 02, 2023 9:30 am “upgrade to Sonoma”
So far that appears to be an oxymoron.
Posted: Mon Oct 02, 2023 12:35 pm
by mikehalloran
Native Instruments is not recommending it yet. The issues appear to be more with the controllers than the VIs or plugs, however.
Posted: Mon Oct 02, 2023 2:41 pm
by mhschmieder
Although I don't recommend going to Sonoma this early, on a matter of principle, the "double-click" on menu might be by design as there seems to be an unfortunate new UX trend in that regard, which I'm noticing on some of my work apps on Windows at the office.
Posted: Mon Oct 02, 2023 3:00 pm
by HCMarkus
mhschmieder wrote: ↑Mon Oct 02, 2023 2:41 pm
Pretty sure that's not the case here. Especially in light of the fact it appears to be limited to DP among DAWs.
Posted: Mon Oct 02, 2023 4:11 pm
by mhschmieder
On the other hand, if they did it for Windows, their identifier for code-switching may not recognize however Sonoma marks itself, so there's a possibility some of the code is trying to operate as though on Windows. This was a big problem when Apple switched the naming convention for the OS as no prior substring for OS recognition worked on both naming schemes.
Anyway, hopefully it'll get fixed soon and isn't an indicator of bigger issues.
Posted: Thu Oct 05, 2023 2:16 pm
by Michael Stewart
I have reached out to MOTU about the double click in the menu bar, they were able to replicate the issue. I am also seeing an issue in working with pitch, it appears to work as normal in the beginning but returning to the window gives the lasso and notes cannot be moved.
Posted: Mon Oct 09, 2023 11:34 pm
by James Steele
I just saw this on Facebook however:
Posted: Tue Oct 10, 2023 10:55 am
by cuttime
James Steele wrote: ↑Mon Oct 09, 2023 11:34 pm
Interesting! I'm really interested in real-word reports on this. Perhaps this even deserves its own thread? M1 vs M2?
