Kontakt 7.8.0
Any reports of DP problems?
EDIT: Initial test drive looks good.
Re: Kontakt 7.8.0
I got so burned last time I won't update Kontakt without running a TM backup first. Here's the change log:
Release Notes
Version 7.8.0 2024-01-29
ADDED
New effects: EP Preamps, Fuzz, Big Fuzz, Stereo Tune
ADDED
Configure double click behavior to replace selected content, or load additional content, via Options → Loading → Files, Libraries, Quick-Load: Double-clicking a file replaces currently selected instrument slot
IMPROVED
Loading speed when switching between snapshots of an actively loaded Instrument from Library Browser
IMPROVED
Increased the font size in Instrument Navigator
IMPROVED
Instrument focus indicator (orange strip on the left of instrument header) is now only visible in Rack View
IMPROVED
Use the resizer from Library Browser all across Kontakt
IMPROVED
Kontakt now supports "Open with.." OS behaviors with samples, creating an instrument that has the specified sample mapped
FIXED
Crash when Kontrol S-Series MK3 Hardware Connection
Service is not installed on macoS
FIXED
Crash when playing a note after changing the output configuration with an already loaded Preset
FIXED
Replika delay in Diffusion mode would not output sound when note duration was shorter than delay time
FIXED
Visual glitches when resizing Kontakt's window across multiple displays
FIXED
Replika delay not recalling delay time values correctly when loading snapshots that switch to Tape, Analogue and Vintage styles
FIXED
CPU overloads during tempo ramps when Replika delay is bypassed
FIXED
Saving a snapshot after opening an encoded NKI, which was resaved after a snapshot load did not transfer NKS
tags
REMOVED
Several entries in Options, which are now permanently enabled:
• "Interface → Show mapping and keyswitches on virtual keyboard®
• "Interface → Auto-refresh Files browser"
• "Handling → Files browser: Double click audio file loads instrument*
ADDED
KSP: New callback type for defining behavior of all U! controls by their ID in a single callback, on ui_controls
IMPROVED
KSP: SEVENT_PAR_SOURCE now works in multi scripts
ADDED
API: link_resource_container command
IMPROVED
API: When creating a resource container, typing .nkr extension is not required anymore
IMPROVED
API: When drag and dropping a Lua script onto Kontakt's rack, it will now be listed in recently used scripts
IMPROVED
API: If there is an error when creating a resource container, dialog will not be created any longer, instead this information will be logged to the terminal
FIXED
API: When creating a resource container, scripts from Resources/scripts folder would not be available to the builder for linking immediately
FIXED
API: When linking a script via
set_instrument_script_linked_filename, the script would not be applied
KNOWN ISSUE
When Kontakt is started from VS Code, logging incoming KSP/API messages is not working (it is working when
Kontakt is started from Sublime Text)
KNOWN ISSUE Hover state missing from new menus, when Kontakt is
hosted as a plug-in on macoS
Vienna Ensemble Pro 7 updated to v. 7.3.3610
Build (3610)
Fixed: Certain operations with VST3 plug ins would take a long time
Fixed: Signals going into the integrated Matrix Mixer plug-in were not processed Fixed: Adjustments for the output meter of integrated plug-ins did not have any effect Fixed Surround Plug-in: Selection for output channel configuration was not possible
Fixed Standalone: Engine Settings were not correctly applied after closing the preferences
Fixed Win: Using the drop down menu inside the Automation panel could cause mini
freezes of several seconds
Fixed Win: Closing projects with VST3 plug-ins would take a very long time
Eventide Recirculate updated to 1.0.2
https://www.eventideaudio.com/my-account/Version 1.0.2 - 1/31/2024
• Added Artist Presets from Count Eldridge
• Fixed delay tails cutting off in some DAWs
• Filter Params are now properly following TONE lock
• Fixed Mono->Stereo Bypass in Pro Tools
• Preset Name now stored in DAW Session
• Clarified the behavior of the BUSS button in the tooltip
STL Control Hub updated to 2.0.5
https://www.stltones.com/pages/download-centerVersion 2.0.5 2024.01
26th January 2024
• Added Will Yip Expansion Pack (free for All Access members)
• Added Transient Designer sidechain filter type control.
• Resolved a latency issue that was causing inaccurate results during null tests following the creation of a Trace.
UVI Workstation updated to 3.1.14
New version released today.
Vienna Synchron Player updated from v. 1.3.810 to 1.3.1137
Recent Changes:
Build (1137)
Fixed: A crash when renaming columns in the dimension tree
Fixed: Timbre Adjust functionality did not consider octave/tuning settings
Fixed: Inconsistent drag-n-drop reordering of slots
Fixed: A parameter sync issue which could cause DC offset on the output
Fixed: First slot not automatically renaming upon adding new patch
Fixed: Mixer channel names not updating properly to reflect the state of loaded presets
Fixed: Mixer FX view sync issue, not reflecting loaded preset Fixed: NKS Lightguide not working properly with VST3 plugin
Fixed: Slot sometimes sticking to mouse pointer while dragging
Fixed macOS: Bad performance.on M1/M2 Ultra CPUs
Improved: General performance on CPUs with high core counts
Added: Master Bus
PSP Old Timer updated from 2.2.1 to 2.2.2
PSP oldTimer and PSP oldTimerME version information
**** 2.2.2 ****
09.01.2023
NEW:
- presets
BUGFIXES:
- AudioUnit: resizing problem - fixed
- Cubase 13: plugin opens in the full-screen window - fixed
NO LONGER SUPPORTED:
- macOS 10.13 and earlier versions
Surge 1.3.1
Re: Surge 1.3.1
Funny, I JUST updated to 1.3.0 yesterday on all my machines.
Thanks for the heads up!!
UVI Falcon 3.0.2 Update Out
UVI Falcon was updated from 3.0.1 to 3.0.2. I have no idea what's new as clicking on the Release Notes link in UVI Portal always opens a PDF that is one version behind. Weird?
Re: UVI Falcon 3.0.2 Update Out
SIDE PEEVE: Version notes without dates.
Yeah... I sent a tech request to UVI asking what gives? I even cleared my browser cache and reloaded the Release Notes PDF on my end to see if it was my error. Seriously... this has been a problem with UVI for a long time now.
Re: Surge 1.3.1
Thanks for posting this. I still had v 1.2.3 installed. I'd fallen a little behind.
PSP Xenon updated to version 1.6.2
PSP Xenon updated to version 1.6.2.
New:
1) Presets.
Bug Fixes:
1) AudioUnit: Resizing problem fixed.
2) Cubase 13: Plugin no longer opens in full-screen window; issue resolved.
3) Minor bugs fixed.
Please Note:
1) macOS 10.13 and Earlier: We are no longer supporting older versions of macOS (10.13 and earlier).
2) Windows Vista and Earlier: Discontinuing support for Windows Vista and earlier versions for better performance and security.
https://www.pspaudioware.com/products/psp-xenon
New:
1) Presets.
Bug Fixes:
Please Note:
