Slow
Posted: Wed Jun 21, 2023 6:20 pm
by Saxplayerz
Dp is slow to respond. If I hit play it’s not instant play it pauses for a few seconds. What could that be?
Re: Slow
Posted: Wed Jun 21, 2023 7:03 pm
by James Steele
Do you see if your count in or preroll is turned on?
Re: Slow
Posted: Thu Jun 22, 2023 11:05 am
by Phil O
+1
Also check your prime milliseconds. Info on this in the Getting Started Guide (not the User Guide).
Slow
Posted: Thu Jun 22, 2023 6:33 pm
by James Steele
If you do find a solution, please come back to this topic and share with us. What makes this site valuable, is the repository of information that people can find when they search here.
Re: Slow
Posted: Fri Jun 23, 2023 6:02 am
by jim2b
I’ve had that happen with lookahead plugins. IZotope Nectar has caused that behavior.
I hope that this helps.
Jim
Re: Slow
Posted: Sat Jun 24, 2023 1:42 pm
by zounds
Yes, same problem here. It's so bad (2-3 second with just a couple of instruments on an M1 Max 64G Mac Book Pro) that I've taken to always running in Live Performance mode, which of course really increases the processor hit (see post "DP Memory Issue in the "Usage, Techniques, Tips & Optimization board).
Re: Slow
Posted: Sat Jun 24, 2023 1:55 pm
by mikehalloran
zounds wrote: ↑Sat Jun 24, 2023 1:42 pm
Are those instruments in one instance of whatever VI player you are using? If so, they are using only one Core. If you run each VI in a separate instance of your player, the OS spreads the load among the cores. Also true with windows.
Re: Slow
Posted: Sat Jun 24, 2023 8:36 pm
by zounds
Yes, using the new Enhanced Instrument Tracks with just one track per instrument.
Re: Slow
Posted: Sun Jun 25, 2023 7:59 am
by HCMarkus
zounds wrote: ↑Sat Jun 24, 2023 8:36 pm
Here, I've had no issue like you guys are experiencing, even while using look-ahead plugins.
I'm sure you have re-booted your Mac... yes?
Have you tried reinstalling DP?
Re: Slow
Posted: Sun Jun 25, 2023 10:51 pm
by Saxplayerz
HCMarkus wrote: ↑Sun Jun 25, 2023 7:59 am
Yes I’ve rebooted the Mac. It’s not the Mac as it works fine in my other daws. No I’m not reinstalling
Re: Slow
Posted: Mon Jun 26, 2023 1:34 pm
by James Steele
Reinstalling DP takes very little time and should not affect your prefs, etc. Don’t know that it will work, but it’s pretty painless to do.
