Masterworks Gate has no linked controls for stereo? I forget this over and over....
....and don't understand it. It's seriously unwieldy. 12 knobs to set individually on a stereo source rather than a linked 6 pair!
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.34
- FMiguelez
Re: Masterworks Gate has no linked controls for stereo? I forget this over and over....
There's a way to join stereo parameters... I think you must press Option (or is it control?) as you adjust them, and some parameters will be linked on both sides.
- Tritonemusic
Yes, the Option key will link the controls, and Command is for more fine-tuned adjustments. You can press them both down at the same time to make fine-tuned adjustments to left and right simultaneously.
DP 10.13, OS 13.7.6, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
Thanks again gents. Of course, this is good info, but a Stereo Link button on the plugin would be awfully nice, too.
That does not work here in DP11.22. I went through every control/option/command/+shift combo and nada. Please explain more.Tritonemusic wrote: ↑Fri Apr 14, 2023 8:34 am Yes, the Option key will link the controls, and Command is for more fine-tuned adjustments. You can press them both down at the same time to make fine-tuned adjustments to left and right simultaneously.
Doug Williams
Tape Op issue 73
DP 11.34
Tape Op issue 73
DP 11.34
- Tritonemusic
All I did was follow the Digital Performer Plug-ins Guide. These are screenshots from there, and it works just as written (but I'm still on DP10.13...not sure if anything has changed since then).EMRR wrote: ↑Fri Apr 14, 2023 10:40 amThat does not work here in DP11.22. I went through every control/option/command/+shift combo and nada. Please explain more.Tritonemusic wrote: ↑Fri Apr 14, 2023 8:34 am Yes, the Option key will link the controls, and Command is for more fine-tuned adjustments. You can press them both down at the same time to make fine-tuned adjustments to left and right simultaneously.
When I hold them BOTH down at the same time, it does what I'd expect; Stereo control with fine-tune adjustments.
I hope that made sense.
Ditto The manual says the option key works, but here, no key combo works.EMRR wrote: ↑Fri Apr 14, 2023 10:40 amThat does not work here in DP11.22. I went through every control/option/command/+shift combo and nada. Please explain more.Tritonemusic wrote: ↑Fri Apr 14, 2023 8:34 am Yes, the Option key will link the controls, and Command is for more fine-tuned adjustments. You can press them both down at the same time to make fine-tuned adjustments to left and right simultaneously.
Tritonemusic wrote: ↑Fri Apr 14, 2023 11:02 amAll I did was follow the Digital Performer Plug-ins Guide. These are screenshots from there, and it works just as written (but I'm still on DP10.13...not sure if anything has changed since then).EMRR wrote: ↑Fri Apr 14, 2023 10:40 amThat does not work here in DP11.22. I went through every control/option/command/+shift combo and nada. Please explain more.Tritonemusic wrote: ↑Fri Apr 14, 2023 8:34 am Yes, the Option key will link the controls, and Command is for more fine-tuned adjustments. You can press them both down at the same time to make fine-tuned adjustments to left and right simultaneously.
Thanks.....just doesn't work here. Didn't in DP8 either.
Doug Williams
Tape Op issue 73
DP 11.34
Tape Op issue 73
DP 11.34
- Tritonemusic
Well, that is weird, guys. I tested it before posting, and tested it again. It still works for me. I wish I could help you figure this out.
Here's a question:
Does holding down Command while changing parameters on any stock DP plug-in make a difference, as far as fine-tuning is concerned?
Here's a question:
yes, Command works for fine turning.
Yes, command has always worked for me. I use that all the time.Tritonemusic wrote: ↑Fri Apr 14, 2023 2:07 pm Well, that is weird, guys. I tested it before posting, and tested it again. It still works for me. I wish I could help you figure this out.
Here's a question:
Doug Williams
Tape Op issue 73
DP 11.34
Tape Op issue 73
DP 11.34
- pencilina
I noticed option (to link channels) not working a year or s ago) to motu tech support, they confirmed and like lots of other confirmed bugs its still broken......
- Tritonemusic
Thanks for the the info, pencilina. I guess that explains why mine's still working (DP 10.13).
