Issue with mixing board automation snapshots.
Posted: Sat Feb 25, 2023 1:53 pm
I'm trying to use the mixing board automation snapshot system, the little camera icon at the bottom left of the mixing board window, and it's not working properly.
I've got a series of loops that I need to do mastering on, so I set up all the loops in a row, all kicks on channel 1, all snares on channel 2 etc...
So I mix down the first 4 bar loop and everything sounds right, I use the mixing board snapshot system to save the entire mix setting at bar 1:1, and I move on to loop 2 to do the mix there, bars5:1 through 9:1 and everything seems to be working, until I look in the track automation list and see that the snapshot automation system is only capturing snapshot values of the first plugin in each channel, the MW EQ, the second and third plugins (10 in total) are not being captured.
The mixing board snapshot system is set to all enabled data types in the mixer but it is still not capturing data for the other 9 plugins in each channel.
Is this a know bug?
Is this a know bug?
