DP11 crashes when using MOTU896HD & 828 Mk2
Dark Goob
Post by Dark Goob »
I have an 896HD and 828 MkII with Black Lion Word Clock & DP8 that I've been using for years with zero issues from my Intel Hackintosh with an older version of macOS.
Recently I got the top end MacBook Pro 16" with M1 Max CPU, and macOS 12. I installed Logic Pro and MOTU Audio drivers, hooked up my 896 and 828 via Firewire plus three(!) adapters, and created an aggregate device in Audio MIDI Setup that has both interfaces. They work 100% perfect in Logic Pro, which I wanted to try out since it was only $199.
However after messing around with Logic for quite awhile, I just... honestly... loathe it. It is simply lacking so many things that I am accustomed to using in DP that I'm not willing to give up, especially Sequences and Chunks.
So I bought the DP11 upgrade and installed it. The MOTU Audio control panel shows the 896HD and 828 Mk 2 are connected.
However, unfortunately, when I open my band's main template project (which works perfectly on the DP8 Hackintosh with the exact same 896 & 828 mk 2), a few seconds after the project window shows up on-screen, DP11 crashes.
The same project opens fine if those two interfaces aren't connected.
Does anyone have any recommendations?
I realize these two interfaces are not officially supported, but I still consider this a bug because there's no excuse for DP11 to simply crash. At worst it should show an error message saying that the selected audio interfaces are incompatible with DP11. It should not allow the user to select those interfaces, then crash.
Let me know if anyone is aware of this issue and if so, whether perhaps there might be a workaround. Thanks.
-=DG=-
_________
Vocals/Synths
Sawblade Painter
https://soundcloud.com/sawbladepainter
Moonbase Zeta
https://soundcloud.com/moonbasezeta
_________
2021 MacBook Pro 16" M1 Max, 64 GB RAM, 8TB
MOTU 896HD (Black Lion Mod) | MOTU 828 Mk II | Korg X2, RK-100S Mk 2 | Yamaha Electone 7000 | Behringer ARP 2600 | Alesis Photon X25 | iPad Pro 12.9" | Line6 MobileKeys 49 | SoundCraft Delta 200 16•4•4 | DP8 & DP11
Re: DP11 crashes when using MOTU896HD & 828 Mk2
Not enough info but I'll guess.
I'll assume you mean DP 11.1. If so, there are a number of threads pointing to System Preferences/Security and privacy/Microphone access issues —if has not selected, check the box then reboot. There are a large number of fixes and changes. There are 4 or 5 threads in the last few days on this.
If the microphone access is selected and you've rebooted, try a Safe Boot of both your Hack and DP. In both cases, start by holding the Shift Key, When booted up and logged in or when DP comes up, qhit, then restart normally. Among the new features, DP now tries to select the best audio interface—this can be overridden.
tvrcek
Post by tvrcek »
Hi,
Thank you for this post. How were you able to load the MOTU 896 drivers with Mac OS 12? When I try to install them, it says you have to have a Mac OS prior to 11?
Thanks in advance for you help!
