DP10 on Asus eee pc box?
tonx
Post by tonx »
Salutations
I wanted to install DP10 on Pc Asus EEE Box:
SO Win 8.1 pro, Intel Atom D525 processor, 4 Gb ram
Below is the review found on the web:
The Intel Atom D525 is a dual core processor meant for nettops, but also used on netbooks. It uses two Atom cores clocked at 1.8 GHz and thanks to HyperThreading, the D525 is able to process four threads simultaneously. The D525 does not have Speedstep and therefore always runs at 1.8 GHz,
The Atom D525 has an integrated DDR2 / DDR3 memory controller and a GMA 3150 graphics card.
The performance of the D525 can be on par with single Intel SU2700 CPUs if both cores are used. In single threaded applications, the performance is significantly worse and barely settles on the level of the 1.8 GHz Atom CPUs.
Could DP10 work well?
PS (Sorry my english depends on google translate)
CharlzS
Re: DP10 on Asus eee pc box?
Post by CharlzS »
I would guess no because it's a different architecture than the Intel Core series which DP lists as a requirement. It's also pretty old and if it did work, the performance would at best be challenging. Only a guess, so email or open a tech case with MOTU for a definitive answer.
tonx
Post by tonx »
The assistance Motu guaranteed me that version 10 worked on this pc. I have installed this version and everything is OK.
