DP 11.04 Released
BobK
DP 11.04 Released
Post by BobK »
DP 11.04 is now available.
Enhancements and optimizations
• Optimized file opening and closing speed.
• Optimized chunk paste speed.
• When a chunk is duplicated, now so are its saved times.
• Saved times in one chunk can have the same names as saved times in another chunk, or in the global list.
• Saved times dialogs now come up in the correct location.
Fixes
• Updated EUCON to respond to the new show/hide plugin message. This fixes a bug resulting in inconsistent show/hide plugin UI behavior on EUCON surfaces when opening and closing inserts.
• Fixed an intel optimization bug that was causing a crash in the Auralizer plugin.
• Fixed per-channel delay UI in N-Channel Delay plugin.
• Fixed non-offline (realtime) bounce to disk.
• Fixed a bug in which canceling non-offline bounce to disk would result in transport playing.
• Fixed a crash that could occur after deleting a chunk with saved times.
• Fixed a bug causing the spline tool not to redraw correctly when moving in certain directions relative to the start point.
• Fixed a bug in MusicXML causing notes to export with "XML_SPACE_ENCODE" when manually assigned to a non-default articulation slot with no assigned symbols.
• Fixed a bug where only MIDI channel 1 would be used for calculating the longest note, this was causing issues selecting notes on different channels.
• Fixed crash bug when recording MIDI.
• Fixed a crash that could occur when selecting a clip in the SE.
Bob
M1 Max Mac Studio - 64 GB RAM - macOS 15.4
MacBook Pro (15-inch, Mid 2012) - 2.6 GHz Intel Core i7 - 16 GB RAM - macOS 14.4 via Open Core Legacy Patcher
DP 11.23
Metric Halo ULN-8 mk4
Re: DP 11.04 Released
Thanks for posting.
I can say firsthand that the Eucon improvements are excellent. It's not just the show/hide plug-in fix, but prior to this version I could not reliably access plug-in parameters via MC Control. I could edit parameters of VIs, but effects plugs just wouldn't display any parameters. Now it's working great!
That can mean anything. I wonder how "fixed" is fixed.
dix
Post by dix »
mikehalloran wrote: Tue Jan 25, 2022 12:32 pm
I think offline bouncing was broken (did not work at all) for everyone. It was for me in 11.03 - maybe before that? It now works again...for me anyway
dix wrote: Tue Jan 25, 2022 1:34 pm
Got it!
waterstrum
Post by waterstrum »
Very nice update!
All is well
bkshepard
Post by bkshepard »
Ooh, it's snappy! :D
-Brian
Mac M1 Ultra 20-core, OS 15.5, 128 GB RAM, DP 11.3.4, UA Apollo x6
bkshepard wrote: Wed Jan 26, 2022 11:00 am Ooh, it's snappy! :D
:rofl: Never gets old.
Indeed. :lol:
artfarm1
Post by artfarm1 »
Wow....everything is snappy indeed! Nice!
Running great as usual!
DP 11, OS Ventura
MacMini 2023 M2Pro, 16 gig RAM, MOTU M6, SSD drives for everything, various sound/sampled libraries from all major vendors, Logic Pro X, DSP-Quattro
MacBook Pro 2015, OSX Monterey, 2.5ghz, 16 gig RAM (w/duplicate software as in MacMini setup)
Trombones: King 2B SilverSonic, King 2B Liberty, & Conn 88H w/Doug Elliott mouthpieces!
http://www.cammillarmusic.com
hammerman
Post by hammerman »
Opening Projects = definitely snappy!
Running fine on my trusty Mac Pro 5,1 with Mojave.
M2 Mac Studio Ultra - 64 GB RAM - Sequoia - DP 11
mhschmieder
Post by mhschmieder »
Snappy for sure! It was taking five minutes or more for DP to open, even though no project was loaded. Not anymore! First time in a few years for such snappy startup behavior! I thought maybe the slowdown was due to the adoption of VST3 and having more work to do with plug-in authentication.
BTD has slowed down for me but I’m thinking that it’s due to now working in 32 bit float. Otherwise, I’m noticing increased snappiness.
mhschmieder
Hmm, I haven't tried BTD yet since the update, but will be doing so sometime this week. As I switched to 32-bit float recently, we'll see.
EDIT: Strangely, DP was slow to launch last night, but I had updated a LOT of plug-ins from Softube, Arturia, and others.
