Bounce to disk with VI's
Posted: Thu Jan 13, 2022 12:49 pm
by charnach
I have VIs (Kontakt) assigned to stereo audio tracks that I set to input for monitoring purposes. In the past, I could bounce to disk leaving those tracks on input and they would be included in the bounced mix. I reinstalled DP (in an effort to resolve an unrelated issue) and now those tracks are no longer included in the bounced mix. Am I missing some setting that enabled me to do that?
Re: Bounce to disk with VI's
Posted: Sat Jan 15, 2022 10:40 am
by mikehalloran
Yes but it’s hard to tell what from your description.
When I did something similar, I wound up deleting the instrument tracks and creating new ones. The MIDI was unchanged. I still don’t know exactly what I did and how but new tracks got me up and running and I’ve not seen this issue again.
Posted: Sat Jan 15, 2022 12:29 pm
by bayswater
Odd. If the monitoring tracks are assigned to the output you’re using for the bounce, it’s hard to know how they could be excluded.
I used this setup too, but I always print the VI tracks on the audio tracks used to monitor before the export, so this has never come up for me.
Posted: Tue Jan 25, 2022 11:20 am
by charnach
Well, I've solved my own issue. Under "Bounce Settings" there is the option: "Bounce includes Audio Patch Through". I'm guessing it got turned off when I reinstalled DP.
