OK, so how are people dealing with clips and timing? I am just getting into the Clips window and having some fun, but what to do with my habit of giving myself a bar of nothing before beginning a piece? Clips seem locked into even numbered queue grids, which would be pretty much fine if I could offset them by a bar. But the grid always begins at the beginning of the sequence.
Anyone else run up against this? Solutions? Is this a feature request or am I missing something? Is it a workflow change for me, to stop having an empty bar at the beginning of a sequence?
Clips and timing
Clips and timing
27" iMac 4.0GHz (late 2015), 32G RAM, OSX 10.13.6, DP10.01, UAD Apollo Duo TB, MTPAV USB (also 2021 14" MBP M1 Pro, 32G RAM, Apollo Twin Duo TB)
Re: Clips and timing
In the Clip editor you can save a clip to start a whole bar early then loop etc. ie you should be able to use them without giving up a lead in bar. Otherwise they’re tied to at least a quarter note lead in when fired
Ah, thanks. I was able to set the start time of the clip to a bar earlier and keep the loop start where I wanted it, so yes, I can get my desired result. Many thanks.
I will say, though, that I went though a LOT of instant crashes while trying to adjust the loop start time. Don't know if it's just this project, that loop, or what...not going to track it down now, i found a workaround that seems to have eased the issue - which makes me think it was a corrupt file somewhere.
Oops, spoke too soon. Still getting instant crashes when I make edits in the Clip Editor of the Clips Window.
