Hello,
Hoping someone can help me solve the following problem:
In DP 9.52 when I'm working in 29.97 drop frame, if I open the sequence window to zoom in on an audio file waveform, DP 9.52 locks up with the eternal spinning color wheel. It takes forever to zoom in and out of files. This does not happen when I'm working in 23.976 frames per second. It also doesn't happen if I open the same project in DP 8.07 where I can work in 29.97 drop frame without issue. Very weird, very frustrating, because I need to be able to work in DP 9.52 for plugin compatibility reasons.
Does anyone have any suggestions on how to fix this issue so that DP 9.52 can function properly in 29.97 drop frame??
Thanks in advance for you help!
Joel
DP9.52 sequence window locking up in 29.97df
DP 9.52, MachFive 3, MX4, Kontakt5, Omnisphere, PLAY, 828mk3 Hybrid FW-USB2, 8-Pre, MIDI Express XT, Mid-2012 MacPro 2 x 3.46 GHz 6-Core Intel Xeon, 64 GB RAM, Graphics Radeon RX 580 8192 MB, OSX 10.14.6.
