Microbook II not appearing on M1 iMac after update to 11.5.2
Posted: Mon Aug 23, 2021 6:33 pm
by nick danger
It still works on my 2009 iMac. Anyone else having this problem? Doesn't show up in Audio MIDI setup either. Reinstalled latest drivers, but no go.
Re: Microbook II not appearing on M1 iMac after update to 11.5.2
Posted: Tue Aug 24, 2021 7:33 pm
by eliercaro
Same problem here, Microbook IIc but with Mac intel bigsur 11.5.2 doesn't work.
Posted: Wed Aug 25, 2021 5:12 am
by nick danger
Haven't had a chance to try it yet, but this is the response from a tech link query I posted----
Thanks for reaching out. I'm not sure how a maintenance update would change this if you were already on Big Sur. But here's what I would try anyways.
- Unplug your MicroBook II
- Open a Finder window and go to Applications. Move CueMix and all other MOTU applications to the Trash
- Once you've done that, go to Macintosh HD > Library > Extensions > move the MOTU.kext files to the Trash (there should be 4 of them)
- Restart your computer
- Next, go to motu.com/download and get the MOTU Audio Installer for Mac v1.6.83634 | Jan. 2, 2020
- Run the installer.
- Restart your computer again once it completes
- Immediately after restarting, go to System Preferences > Security & Privacy > General tab > and ALLOW the blocked MOTU software to run.
- You should be able to plug in your MicroBook II and get it recognized.
Thanks,
Brendan - MOTU
Posted: Mon Jan 10, 2022 2:24 pm
by 1sec
Hi Brendan,
I am facing the same problem, unfortunately there is no 2020 version of the Motu Microbook II driver.
Latest driver is 2017 (73220).
Can you please upload the 2020 driver?
I did all the above steps and still my Motu Microbook ii is not recognized.Also tried different USB ports/cables.
I am running on Macos Mojave (10.14), Macbook Pro (15'' mid 2015), fresh install, just for the music.
I downgraded to 10.14 (from 10.15) just because I could not find a driver for Catalina.
Also I had it running before, 3 years ago on the same Macbook.
Following your install guide there is no "Allow" button, maybe it is already allowed since I pressed the button on the installation before.
How can I make the interface run please?
Kind regards
Posted: Mon Jan 10, 2022 4:36 pm
by Kurt Cowling
I have a MicroBook IIc and have to go through this every time there's an update to MacOS. Follow the instructions given earlier in this thread to install the most current driver. If CueMix FX doesn't see your interface do the following:
Quit CueMix FX
Open Terminal and run this:
sudo kextutil -v /Library/Extensions/MOTUMicroBookAudio.kext
(You'll need to provide your admin password)
Quit Terminal and restart your computer.
Unplug and replug your Microbook II.
Launch CueMix FX.
It should now see your Microbook.
--Kurt
Posted: Mon Jan 10, 2022 9:48 pm
by 1sec
Hi Kurt,
thank you for responding.
I tried your tutorial but it does not go on my system. Microbook still not showing, neither in Audio Setup nor in CueMix FX.
Maybe the firmware update is faulty.
The interface also came with a CD, but I don't even have a CD-Rom anymore .... :)
The firmware update was possible though.
Kind regards
Posted: Mon Jan 10, 2022 9:58 pm
by 1sec
Hi Kurt again,
actually now it goes :D :D :D
Thanks alot man.
How did you find that out?
Greetings from the country NI comes from :)
Posted: Mon Jan 10, 2022 11:33 pm
by HCMarkus
Fookin' great Kurt. :smash:
Posted: Tue Jan 11, 2022 12:37 am
by mikehalloran
1sec wrote: Mon Jan 10, 2022 9:48 pm Hi Kurt,
Kind regards
The last Firmware update was from 2013, eight years ago. I'm going to guess that's not the problem. You need the correct driver:
MOTU Audio Installer Mac v89555 | Oct. 13, 2021 macOS 12, macOS 11
Then you need to allow it under System Preferences/Security
See my posts in this thread on how to find and install it.
viewtopic.php?f=2&t=69619
Since you're running Big Sur, you do not need the older driver.
Posted: Tue Jan 11, 2022 6:42 am
by Kurt Cowling
Glad it worked. I got that from MOTU tech support after the steps for installing the latest driver didn’t solve the problem.
Good news… it works, although you might need to replug the unit more than once. Bad news… you’ll probably have to do this after every MacOS update.
I hope to get back to the place “where NI comes from” again someday. I’ve been there several times and love it there, but international travel is so unpredictable right now.
