I'm interested in having my 2017 iMac boot from an external SSD rather than the internal Hybrid drive. I'd probably get an OWC Envoy Pro EX. I really don't want to open up the iMac and replace the internal drive if I don't have to. Right now I'm on Catalina but plan to go to BigSur when all my software is ready.
Anything about this that is problematic? Will I have trouble updating/upgrading OS when it's on an external drive? I remember there being some discussion here but can't seem to track down the exact conversation.
Also, I will probably want to keep my Apple Music library and photos on the hybrid drive to save space on the SSD. I have no experience with Terminal or the like. Hopefully that's not too complicated.
Thanks for any insights!
--Kurt Cowling
External SSD boot drive for 2017 iMac
- Kurt Cowling
DP 11.34 , 2021 MacBook Pro M1-Max, 2017 iMac Retina 5K 27-inch, Omnisphere, Trilian, Stylus RMX, EZ Drummer 2, Falcon, Real Guitar, Sample Modeling brass. Audio Modeling reeds, strings, Kontakt 6, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, PSP Impressor, Altiverb 7, Izotope RX10 Standard, Yamaha S-90ES, Yamaha MOXF-8, Yamaha MX60, Sibelius subscription, Adobe CC and Motion 5.
Re: External SSD boot drive for 2017 iMac
Hi Kurt, since you have a Fusion drive the best performance really is opening it up, replacing the internal SSD with a fast NVMe 3 x4 blade like the 970 EVO. Your iMac has a Samsung blade inside.
$349 for 2TB https://smile.amazon.com/Samsung-970-EV ... ref=sr_1_4
plus a $15 pin-out adapter. https://smile.amazon.com/Sintech-Adapte ... ref=sr_1_4
The OWC Aura Pro X2 has the correct pin-out but costs $85 more.
Then, if you need more storage, install a SATA III SSD in the remaining space, 1, 2, 4 or 8TB. $90–$750. You can have the two configured as a monster, all solid state fusion drive or as separate drives.
https://smile.amazon.com/SAMSUNG-870-QV ... ref=sr_1_3
Installation runs around $75–$100 here in the Silicon Valley (it doesn't take 20 minutes + data transfer for an experienced tech). You might want to call around.
The only 2 externals I can recommend for booting are true Thunderbolt 3. Anything else is slower than your 2017 iMac (USB 3.2 etc.).
4TB https://eshop.macsales.com/item/OWC/TB3ENVP40/
2TB https://www.amazon.com/Samsung-Portable ... 07GBWZJFG/
When you consider that the least expensive 2TB external is $600, it makes sense to consider replacing that tiny blade in your iMac. I forget if the original blade is 64GB or 128GB on a 2017 Fusion.
- Kurt Cowling
Thanks so much for your insights. I’ll look around and see if there’s a tech in my area that can do the internal replacement.
Sorry I didn’t reply sooner. I didn’t get an email telling there was a reply and then I’ve spent most of the week severely under the weather.
