Behringer MX32 into DP?
Posted: Sun May 02, 2021 5:23 pm
by uncle dunc
DP 10 on a Mohave Mac laptop, using the USB connection, I can get Audio/MIDI set up to find the MX32, but no MX32 inputs show up when assigning an input to a track in DP. I only get "built-in 1 or 2" and a bunch of busses, and there are no options in "clock mode", only "internal". I've also chosen the MX32 in the "sound" menu in System Preferences.
I don't have the MX32 here, it's at a venue, but if anyone has suggestions I could try them next time I'm there.
Re: Behringer MX32 into DP?
Posted: Sun May 02, 2021 7:08 pm
by mikehalloran
A search does not show up a product called a Behringer MX32. X32 refers to many different Behringer units.
Do you have a link?
Posted: Sun May 02, 2021 7:49 pm
by MartinBaird
Assuming you mean the X32 family of mixers. Yo may need to go to the Bundles window in DP and add inputs and outputs there first.
If that doesn't work you might also check out dbbaudio.com I bet he has a good article to show you everything on the X32 end you need.
MB
Posted: Tue May 04, 2021 1:05 pm
by daniel.sneed
Well, I don't see X-32 in my DP inputs either.
I have an X-live card in my X-32, connected to my Macbook thru usb, and I do see X-live inputs in DP.
Before X-live, I had an X-usb card, same behaviour.
All is working fine here with that setup.
Posted: Tue May 04, 2021 1:27 pm
by MartinBaird
You say that you do see X-Live inputs in DP. Then you're good to go. That's the X32.
MB
