Sending MIDI out of Audio Units plugins
Posted: Sat Apr 10, 2021 2:51 pm
I have been trying to send MIDI out of Audio Units plugins inside Digital Performer for some time, until I found a few things I want to share here.
Since the beginning, my DP is set to handle MAS and AU plugins, so each time I install a new virtual instruments I do not install the VST version.
Recently I tried to play with Scaler, Instachord, HY-RPE2 and many other patterns generators inside Kontakt and tried to send the data stream out to other virtual instruments thru dedicated MIDI channels. But AU doesn't support sending MIDI out of audio channels. And nothing worked. I read sometimes that the AU version 3 now supports it, technically. But As I understand, few AU plugins on the market have implemented that feature. At least, Digital Performer as it handles AU plugins has hard time dealing with it. So my advise is, if you want to use theses plugins and feed other virtual instruments, use the VST version (Kontakt, Hy-RPE2, Scaler etc). You can do so without reinstalling all your plugins if you use Blue Cat's Patchwork. This is a powerful wrapper and more.
Insert on the first slot of a row your MIDI generator (ex Kontakt+Riff Generation), send the MIDI out to a dedicated MIDI channel (ex: port A), and add any number of virtual instruments inside Patchwork and set their MIDI in to port A. If you want, you can send the audio out of each instrument to separate virtual channels and inside DP, create AUX tracks, each receiving a unique instruments, add insert or effect for each of them if you will in the mixer.
It works great.
Sadly, Ableton Live and Apple Logic can handle these type of plugins much more easily. I wish Digital Performer could handle MAS + VST + AU plugins at the same time and have what is now called MIDI FX. It is a shame that the MIDI inserts in the mixer are the same 12 or so since the last 30 years.
For example, I would like to have a MIDI FX to create a keyboard split. Live has it and it is very useful. Please MOTU, shake your...
It works great.
