Tempo Scale on the Conductor Track: Broken?
Posted: Sun Mar 14, 2021 5:26 pm
by bayswater
I've been trying to set the scale in the conductor track to show tempos varying from 0 to 120. The usual method is to drag over the values you want shown beside the scale. When I do this, I get a number of odd results:
Instead of 0 to 120, I might get 120 to 600.
Or I might get 0 to 30.
Or I might get a scale that shows the same values twice -- i.e. it runs from 0 to 300, then from 200 to 600, showing 300 twice, with some of the values partially invisible.
Is this function broken, or has the way of controlling it changed?
EDIT: Works fine in High Sierra. Doesn't work in Mojave.
Re: Tempo Scale on the Conductor Track: Broken?
Posted: Mon Mar 15, 2021 9:36 am
by stubbsonic
Working in Mojave and DP 9.52 here-- with one quick test.
To be clear, you're talking about graphical editor view's vertical zoom/range (not the "scale tempo" function).
(As an aside, DP 9 is pretty crashy in Mojave for me-- so far no major lost work. Not trustworthy at all, though.)
Posted: Mon Mar 15, 2021 12:33 pm
by bayswater
stubbsonic wrote: Mon Mar 15, 2021 9:36 am Working in Mojave and DP 9.52 here-- with one quick test.
That's right. I don't remember it not working in V9. I vaguely recall a few graphic things broken in Mojave.
