Audio recording too early
- dado
I don't understand why sometimes DP records my audio too early. This is not some note ( and therefore my mistake ). I have to make a restart and then it works
iMac 27" 3 ghz 32 Giga ram / DP 11 / Motu UltraLite mK4/ TLAudio Ivory 5051 / Addictive Drum2 / PRS Custom22 Guitar / Boss Katana100 / Line 6 Variax700 / Strat by Tino Tedesco
- greg328
As I understand it, with a recent update of digital performer, it’s always recording even when not in record mode. Is this what’s possibly happening to you? The waveform should not appear on the screen however, until you enter record mode. Possible you have auto punch-in enabled?
- dado
Re: Audio recording too early
Not my case but thanks for the answer
It is only MIDI that is always recording.
In DP10.11 and .13 (and possibly in earlier versions as well), if one changes DP's buffer size while a track is record-enabled, timing will be off for subsequent recordings on that track. Disable and re-enable recording to get things back on track.
- dado
Normally I use the lower Buffer ( 32 ) for audio recording, but how I told, with a restart of Mac is solved, but anyway very strange....
