Bizarre MIDI Problem
Posted: Sun Mar 08, 2020 9:46 am
I don't know what to make of this, the latest in a series of frustrating nuts and bolts problems with DP 10.11. It's one thing after another. The latest is MIDI pitch errors while editing in the Sequence window, and for the life of me cannot understand it and so cannot correct it.
I click a note and what sounds is a short grace note one half step above the note, always a half step. It is random as to what note and when and similarly stops randomly. The only thing that's predictable is that it happens on every session, both in Kontakt and Play. I can't make it happen and I can't not make it happen. Imagine editing when you drag a note to change its pitch but sounds a half step higher when you release the mouse!
I disconnected all MIDI devices, deleted prefs. MIDI monitor shows the correct notes are being transmitted. This does not happen with DP9.
What could this be?
What could this be?
