DSP Quattro 5.1 is here...
Re: DSP Quattro 5.1 is here...
Ha!
It was my plan to reactivate it on my iMac Pro so I went in this morning to download whatever was sitting in my account. I didn't notice it was now 5.1 and the additional functionality—nor would I had I not seen this.
Thanks for the heads up!
![happy :dance:](./images/smilies/dance.gif)
Had to go back and find the release notes:
Version 5.1: 19.06.29:
⁃ New: BatchProcessor, very much more powerful respect the one of v4.
⁃ New: no need to save the Project in advance before to work with it
⁃ New: new command on the audio file editor to save your edits replacing the source audio file on MacOS file system, outside the Project, with only one mouse click.
⁃ New: ISRC codes embedded in WAV files are fully supported
⁃ New: import/export of audio files in FLAC format (only HighSierra or newer)
⁃ New: it is now possible to rename audio file and other items on the Documents list by right-mouse clicking.
⁃ New: Zoom In/Out on the position of the mouse pointer: keeping the control key pressed while using the mouse scroll-wheel, DSP-Quattro does a zoom In/Out around the position of the mouse pointer and not around the Playback cursor
⁃ New: Playback Cursor Follow OFF or Follow Next Screen options
⁃ New: row selection on AudioCDLayout Audio Region and CD-Track tables has been revisited and improved. It is now possible to click on the Speaker on a row of both tables to jump to that AudioRegion/CD-Track starting the playback.
⁃ New: additional options on Preferences
⁃ New: recording mode has been revisited. New MonoLeft and MonoRight options for mono new recordings.
⁃ AudioCDLayout graphic engine is drastically faster redrawing when shifting AudioRegions, setting cross-fades, trimming AudioRegion start/end.
⁃ AudioCDLayout PDF Sheet has been revisited.
⁃ fixed a potential un-compatibility closing some AU plug-ins causing a crash.
⁃ code optimization and bug fixing
⁃ compiled using the Apple SDK for MacOS 10.14 Mojave, tested also in dark mode.
It took me some futzing around to find the batch processing. It's in the Document Manager on the left. R-click on a file to add it to the Batch Processor. Time for a manual update!
828x MacOS 14.5 M1 Studio Max 1TB 64G DP11.32
I have ver 4. Is 5 a paid update? I can only find the demo download and no place to enter a license code. Help!
Yes, only paid. Stefano offered it on sale last year for $39, I think, and I jumped on it. The regular upgrade from 4 to 5 is $99. There's always the demo...MIDI Life Crisis wrote:I have ver 4. Is 5 a paid update? I can only find the demo download and no place to enter a license code. Help!
I think I got ver 4 cheap. I never use it...
The Batch processing function is great to have now that the Audiofile Engineering apps seem to have disappeared...
MacBook Pro 2021 (M1 Ultra) with 64 gigs RAM. DP 11.23
This is a nice update to a very capable app, but I still prefer and use DSP Quattro 4 99% of the time. 5.1 at least lets you edit files without having to create a new project, but it's still way more complicated than it needs to be for most things I use it for. 4 feels like a handy utility, compared to to 5, which seems more for large complicated operations. I sure miss PeakMIDI Life Crisis wrote:I have ver 4. Is 5 a paid update? I can only find the demo download and no place to enter a license code. Help!
![Sad :(](./images/smilies/icon_sad.gif)
And, yeah. The website is confusing! After you pay for the upgrade the download should appear in Your Licenses in the User Area (not in the Download area)
Maybe you needed to do a refresh. 5.10 does appear in my licences list.dix wrote:This is a nice update to a very capable app, but I still prefer and use DSP Quattro 4 99% of the time. 5.1 at least lets you edit files without having to create a new project, but it's still way more complicated than it needs to be for most things I use it for. 4 feels like a handy utility, compared to to 5, which seems more for large complicated operations. I sure miss PeakMIDI Life Crisis wrote:I have ver 4. Is 5 a paid update? I can only find the demo download and no place to enter a license code. Help!
Random items...
The upgrade price is $49. It is the new license that is $99.
https://www.dsp-quattro.com/dspquattro/Site/store.html
Since it is 32 bit, DSP-Q 4.x cannot run 64 bit only plugins if that’s a thing for you.
I did a few large projects in DSP-Q 5 over the last few months and am quite used to the workflow now. Now that I have the hang of it, I find it fast and easy and can’t believe I’ll ever fire up DSP-Q 4 ever again. A few things are not intuitive but it’s a matter of knowing where to look — thank goodness there’s a manual, now.
I only did batch processing in 4 once just to see how it worked — very well but I preferred TwistedWave which has been 64 but for a long time. I’ll give 5.1 a shakedown at some point to see if that changes. TW is so easy for that task.
I haven't even downloaded this update but it solves 99% of my issues with DSPQ5, I'm pretty happy!
Mouse wheel zoom, batch processing, and not having to save a project on opening a WAV or AIFF file is great!![rockin :headbang:](./images/smilies/headbang.gif)
- sdaino
Hello,
I see that you are talking about DSP-Quattro 5.1, maybe this can help:
There are dozens of little and major new things and improvements, the most important are addressing three major matters:
• New: BatchProcessor, very much more powerful respect the one of v4.
• New: no need to save the Project in advance before to work with it
• New: new command on the audio file editor to save your edits replacing the source audio file on MacOS file system, outside the Project, with only one mouse click.
The last feature listed above allows to load an audio file on the AudioEditorView, do some edits, and save the edits back on the source file on MacOS finder exactly as doing "Save" when working with v4.
To see the BatchProcessor, just click on the Batch button on top of the Project main view. To load files over there, just drag the files from the MacOS finder or from the Document Table over the BatchProcessor table, DSP-Quattro will load them on the BatchProcessor and you will be ready to go.
The update of the user manual will be available shortly. I'm also preparing a video tutorial about using it and about what's new in version 5.1.
Version 5.1 is a free upgrade for all 5.x registered users. The full archive is into the user area, just log-in and go to "YourLicenses", your last full version of DSP-Quattro is always there. It does not require re-authorization, of course.
For users registered to previous 1.x, 2.x, 3.x , 4.x versions of DSP-Quattro, the upgrade to version 5.x is available for 49US$ at our web store.
If you have questions, doubts, requirements or if you will need assistance, do not hesitate to write to me at support@dsp-quattro.com
Stefano Daino
http://www.dsp-quattro.com
Stefano Daino
I was just using the batch processor in v4 yesterday. Nice to see this is added. Will download the update now!!
- philbrown
[/quote]dix wrote:This is a nice update to a very capable app, but I still prefer and use DSP Quattro 4 99% of the time. 5.1 at least lets you edit files without having to create a new project, but it's still way more complicated than it needs to be for most things I use it for. 4 feels like a handy utility, compared to to 5, which seems more for large complicated operations. I sure miss Peak![]()
I bought 5 but use 4 (every day) so I don't have to create a project. I use it a lot to generate DDP files, mp3's etc for distribution and the project step is unnecessary for me. Can I do that in 5.1 without creating a project? I'm on the road, but will try it when I get home.
I don't even know. I feel bad saying it because the developer is so diligent and clearly put a lot of work into it, but I avoid using DSP Quattro 5.1 entirely. I get annoyed and hit workflow roadblocks whenever I try to use it. Version 4 is still great though.
