For whatever reason, my system does not like Soundflower - not at all! The last time it was on my system it was installed (without asking) by Finale. I finally figured out what was causing the problem and got rid of it. When Soundflower is installed on my system clocking in DP goes south.
Now that every thing is... err, was back to normal I launched an extra that came with Roxio's Toast 17 - Live Screen Capture. Guess what? It installs Soundflower. I'm getting a little tired of this. Even after I've removed what I think are all the Soundflower components clocking still goes wonky from time to time.
Damn it. I'm sick of troubleshooting.
Phil
DP 11.32, 2020 M1 Mac Mini [9,1] (16 Gig RAM), Mac Pro 3GHz 8 core [6,1] (16 Gig RAM), OS 14.5/11.6.2, Lynx Aurora (n) 8tb, MOTU 8pre-es, MOTU M6, MOTU 828, Apogee Rosetta 800, UAD-2 Satellite, a truckload of outboard gear and plug-ins, and a partridge in a pear tree.
What version? I used V1.66 or something like that for a long time without issues (because it had the 64 channel driver), but after an OS update a year or so back, it went berserk. V2 does work OK for me, at least under HS.
Thanks for the heads up on Live Screen Capture. I spent a few minutes with it, then said “Oh hell no!” Then I used APFS Snapshots to roll my system back a half hour so I wouldn’t have to troubleshoot and uninstall. Didn’t know what happened except that I didn’t want any part of that.
I still use Soundflower now and then, mostly to snag audio for my dad that I can’t find anywhere else.
I remember cleaning it out of the root directory after upgrading El Cap. Don’t recall what version I have now nor how I got it working... but it behaves for me now. Guessing that it’s 32 bit and will cease to function later this year, assuming I have a Mac that can run the next OS. At that point, I’ll find something else that works, no doubt.
DP 11.31; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1 2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.5 b4, USB4 8TB external, M-Audio AIR 192|14, Mackie ProFxv3 6/10/12; 2012 MBPs Catalina, Mojave IK-NI-Izotope-PSP-Garritan-Antares, LogicPro X, Finale 27.4, Dorico 5.2, Notion 6, Overture 5, TwistedWave, DSP-Q 5, SmartScore64 Pro, Toast 20 Pro
Well I'm using a program called Loopback now that seems to be working well. So I'm not going back to Soundflower even if they de-bug it. (de-flower it? )
Now I have to figure out what remnants of Soundflower are still present and causing issues.
cuttime wrote:The .kext extension is the one to look for.
Yeah, it turns out there were two - one in Extensions and another in StagedExtensions. I just found and deleted the second one and we'll see how that goes.
Philippe
It's StagedExtensions. That folder has two folders within - Library and System. Each of those folders has .kext files in sub folders.
Phil O wrote:It's StagedExtensions. That folder has two folders within - Library and System. Each of those folders has .kext files in sub folders.
StagedExtensions is in the Library folder. Besides Soundflower, PACE, Roxio, JBridge and MOTU keep a few .kext files there as well.
I've checked my user and boot drive Library folders, as well as my System folder, and there is no Staged Extension folder to be found, only StagedFrameworks. I'm on Sierra (10.12.6) if that makes a difference.
2013 Mac Pro 32GB RAM
Well, the bottom line is things seem to be back to normal now that I've found that second .kext file. I haven't seen any problems since its removal.
Phil
