DP 10.0 AAF Import Crash
CT
Post by CT »
An AAF import to DP 10.0 does not work for me. (OS 10.11.6 partition). It crashes DP every time.
The same AAF imports correctly to DP 8.07 (OS 10.10.5 partition).
I know there are workarounds, but this is not good for workflow.
Has anybody else experienced this?
2 x 2.8 Quad core Intel Xeon, 10.10.5, 16GB, DP8.07, 828mkII, Ensemble, Waves, Sonnox, iZotope, MachFive3, Kontakt, MC Control, MC Mix, VE Pro5.
dix
Re: DP 10.0 AAF Import Crash
Post by dix »
Seems to be working for me with DP10 and 10.11.6. ...some more info here might be helpful viewtopic.php?f=26&t=66137
apanacci
Post by apanacci »
As I have said a few times, dont bother trying to get it to work. Open it ai Audio Desk and save as a DP file
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
CT
Post by CT »
Thanks for your replies. Motu has acknowledged the AAF bug. The Audiodesk workaround is good to know, even if it does interrupt workflow when dealing with big projects.
