Two Issues
Posted: Mon Feb 04, 2019 2:13 pm
Hi,
Was going to ask a tech question and then just discovered another hard disk issue so am trying for a two-fer here.
1. I just realized I lost one of my VI drives, an HD with two partitions. One of the partitions still mounts on the Desktop, but the other does not. I was able to perform Disk Repair on the partition, but it still doesn't mount. It looks like the disk is completely full. I probably accidentally downloaded a couple big VIs onto it by mistake, as I usually try to keep around 100g free. Do I need to erase the disk completely to use it again, or is there any way to surgically erase enough material to get it to mount again?
2. I installed a new SSD in my old 2011 iMac a little more than a year ago. I had a tech do it and he installed High Sierra. My old HD is still active and available, and still on Sierra. I've griped a bit over the past year that with DP 9.52 and High Sierra, some power hungry VIs cause a performance spike and audio glitches, while with 9.02 the performance may spike but the audio doesn't glitch. Out of curiosity I booted up in Sierra on the HD, and discovered that a particularly troublesome preset didn't glitch in 9.52 under Sierra. Yay! I suppose I could go back to my HD, but the speed with the SSD is just too much to give up.
So.... I wondered if it would be possible to install Sierra on the High Sierra SSD. Would there be an issue with the new file saving format in HS? I have a couple Sierra install zips that could be used, but wanted to make sure first if this was possible or advisable. I've gotten along with High Sierra for the most part, and concerned about security issues going forward with Sierra, but not having the audio glitches would be huge at this point .
Anyway thanks for any help!!
