DP 9.52 Plug-in issues with OS MOJAVE
Posted: Fri Nov 09, 2018 3:01 pm
by Les Hurdle
Upgraded to Mojave......... all went well until I tried to change a plug-in or e.g shift from Spire to Serum.
No matter what, DP crashed.
MOTU insist it is an OX issue....... what might be the answer?
Les H
posting.php?mode=post&f=1&sid=2508af862 ... 0d2e33de29#
Re: DP 9.52 Plug-in issues with OS MOJAVE
Posted: Fri Nov 09, 2018 5:10 pm
by mikehalloran
Motu might be right. Did you reboot? If not, do so and see if you still have a problem.
Try a Safe Boot by holding down the Shift key on startup. Log into your User account when you see the screen. Wait till you see your s=desktop icons rebuilt. This can take 15 minutes or longer—be patient. Reboot normally and see if you still have a problem. This rebuilds paths and fixes generic alias icons as well as resets caches to default.
If that doesn't do it, reinstall these plugins and reboot.
Posted: Fri Nov 09, 2018 9:18 pm
by Les Hurdle
Hi Mike Many thanks
Did all you suggested before posting except re-install the plug-ins........ far too many ;-))
MOTU suggest the issue is OS M prefs....... no idea what they might be though?
Les
