Icon Platform-M iMap software out for Mac
Posted: Mon Feb 12, 2018 7:20 am
by Gravity Jim
Well, it took them long enough, but the iMap software has finally been released for Macintosh. You can get it here:
https://support.iconproaudio.com/hc/en- ... latform-M-
Best feature? Being able to update the firmware. You really do have to connect the Platform-M directly to your Mac (not through a USB hub, for example) as per the instructions for the update to succeed. Just updated mine from 1.0 to 1.14 (iMap automatically downloads the latest firmware from the Icon website).
Re: Icon Platform-M iMap software out for Mac
Posted: Mon Feb 12, 2018 6:01 pm
by James Steele
That's very good news. Having that software move from vaporware to the real deal makes a big difference and makes their product look much more attractive.
Posted: Mon Apr 02, 2018 4:37 am
by joelmusic
Hello Gravity Jim -
I was wondering if you knew the answer to something...
I just bought a Platform M+.
In iMap, I have it in 'user defined' mode and most things are lining up with DP.
I would like to be able to use the Read and Write buttons to enable automation so I can overwrite (or not) volume data.
Those buttons aren't mapped.
I've been looking through DP and don't see a way to enable automation except by physically clicking it - and there don't seem to be any key commands except to bring up the automation setup.
Do you know a way to do this?
Thanks! :)
Joel
Posted: Mon Apr 02, 2018 8:15 am
by Klaus
Bummer, the new Mac iMap doesn't read WIN-generated mappings...
Iconpro knows about it...
While we are at it...
2 Platform M are not seen by AMS as 2, only 1, in OS 10.7
2 BCF2000 are seen as 2...
Does anyone know a tool that can help ?
Best
Klaus
Posted: Sun Jul 15, 2018 1:16 pm
by ivorysteve
Hey, Gravity Jim,
Piggybacking on this thread a bit, as you're the Icon Platform-M / DP expert. I'm considering getting a Platform M, specifically to use the faders to automate Expression (CC11) data with DP. Maybe I'm missing something, but in all the posts I've seen on this site on this, I haven't seen this mentioned as a feature on the web page or in the manual. Is this possible (using the iMap software, maybe), that you know of?
Thanks for any insight!
Steve
Posted: Mon Jul 23, 2018 12:20 pm
by Gravity Jim
I don't know the answers to these questions, because I'm not a Platform-M "expert:" I just own one, and I don't use it for anything but mixing tracks.
I assume you can program it to send any CC# messages you like, save the config and recall it through the companion software at any time. But I haven't tried that, so I don't know for sure.
The Read & Write Buttons? I haven't even tried them. I guess I assumed they were married to the master fader, since they live on that strip. No clue.
Klaus, are you saying you want DP to see the two as separate devices?
Posted: Mon Jul 23, 2018 10:52 pm
by supersonic
It does work. However, you need to set it up with the IMAP software and delete it from the Control Surface setup. The setup I am considering is continue using my present M+ as daw controller while setting up an extender I stand alone MIDI mode. This supposedly will work. What this means is that one of them will be as Control Surface, while the other will act as MIDI controller, setup with the iMap software
Posted: Tue Jul 24, 2018 12:06 pm
by Klaus
Gravity Jim wrote:I don't know the answers to these questions, because I'm not a Platform-M "expert:" I just own one, and I don't use it for anything but mixing tracks.
Yes, in 10.7 this is not the case, but in 10.8 two identical Platform M are seen as 2 devices...
Is it possible to use a later AMS ( from 10.8 ) in 10.7, and how ?
Klaus
Posted: Wed Jul 25, 2018 12:49 am
by supersonic
For the read/write buttons you click on one of them and then you hit the select button of the track you want changed.
Posted: Fri Feb 28, 2020 8:39 am
by rjaret
supersonic wrote:It does work. However, you need to set it up with the IMAP software and delete it from the Control Surface setup. The setup I am considering is continue using my present M+ as daw controller while setting up an extender I stand alone MIDI mode. This supposedly will work. What this means is that one of them will be as Control Surface, while the other will act as MIDI controller, setup with the iMap software
Hi Supersonic. Have you tried MIDI mode yet? I'm curious if the MIDI data will also drive the faders, either for just volume/pan (cc7/cc10) or other cc values like expression (cc11).
