DP 9 and VEP6 - preserved instances not connecting
Posted: Thu Jan 25, 2018 8:19 am
Hi there,
I have updated to VEP6 and DP9 and still can't make the preserved instances connect.
When I try to insert a VEP 6 pro in my DP9 session so that I can connect it to my VEP 6 server (where I have my vienna loaded) DP 9 crashes with a message error.
I already tried the fix that you guys have sent me:
Workaround fix for VE Pro 6 plug-ins in DP 9.51 on macOS High Sierra
1.) Run the Vienna Ensemble Pro 6 (OS X) build 6.0.16778 installer from https://www.vsl.co.at/en/MyVSL/software_installers. Restart the computer.
2.) Open the Applications folder and drag the Digital Performer application to the trash. If you have multiple versions of DP, be sure to drag all versions to the trash.
3.) Hold the Option Key while clicking on the Finder's "GO" drop-down menu, select Library, then open the Preferences folder. Find the com.motu.MotuAudioSystem folder and drag it to the trash. Empty the trash.
4.) Download the DP 9.51 installer available at motu.com/downloads and run the installer.
5.) Find the VST folder (System HD/Library/Audio/Plug-Ins/) and rename the folder to anything other than “VST” (for example, “VST_temp”).
Your Audio Unit and MAS VE Pro 6 plug-ins will now be available in Digital Performer 9.51.
The only drawback with this workaround is that no VST plug-ins (only AU, MAS and AAX) will be available on this system as long as the VST folder is not named "VST"
-------> And still not working...if anybody has a sugestion please let me know.
Best,
Ron
http://www.ronlobomusic.net
Best,
Ron
