Cannot Record VIs into Audio
Posted: Sun Dec 24, 2017 4:45 pm
I must be doing something stupid ....
I cannot get audio into audio tracks for recording from a virtual instrument track. I see the signal in the Audio Monitor, but the track shows nothing, and there's no sound.
Here is the setup, I created a simple project to troubleshoot:
Bassline is instantiated as an instrument track, output set to Bus 1-2 (MIDI track assigned to control).
Audio track is setup with its input set to Bus 1-2
Audio track is record-enabled. The little blue speaker is enabled to indicate monitoring is switched on for the audio track.
I hear everything fine with Bassline set to Built-in audio as the output. Set it back to bus 1-2 (with audio track input set to same) and silence. Again, I SEE the blue VUs moving in the Audio Monitor.
I have everything selected in Configure Hardware Driver. What moronic thing am I missing?
DP 9.5
Mac Pro 4.1 upgraded to 5.1
XEON 3.33, 32 GB RAM
DP 9.5
