DP 9.5.1 is up.
ghobish
Re: DP 9.5.1 is up. Happy Halloween.
Post by ghobish »
HCMarkus wrote:
kurtl wrote:Anybody get crackling when saving while playing?
Yes, but doesn't worry me.
That happened with 9.5, I reported it and they said it was a known bug and would be fixed in the next update. Apparently not?
(It doesn't "worry" me either, but it doesn't sound good and shouldn't be there.)
Gary Hobish
A. Hammer Mastering & Digital Media
San Francisco, Ca
http://ahammer.com/mastering
Mastering: Mac Studio M1 MAX 2TB SSD, 64GB RAM, 32-core GPU, OS 12.6; DP 11.22, Waves, Izotope RX10 Advanced, Alloy, Nectar, PSP stuff, Plug-In Alliance, Metric Halo ULN-8 MkIV, Euphonix MC Control & MC Mix, Presonus Central Station, and (still) no air conditioning (but at least now there is airflow)
Annex: Mac Pro 2010 5,1 3.33GHz 12-core, 80GB RAM, 10.14.6, DP 11.22, Metric Halo ULN8 MkIV, MOTU 2408III
KenNickels
Re: DP 9.5.1 is up.
Post by KenNickels »
Re: 9.51 - Can anyone please confirm the following? Right-click MIDI editing still does not work in the Seq window, but works in the MIDI window. Last version working was 9.13. Since I do everything in the Seq window, this is a major inconvenience.
My Box(s): Two Mac Pros 5,1/3Ghz, 12 core, 96GB Ram, OS 10.14.6, One Windows 10 computer, Vienna Ensemble Pro, MOTU Audio Express, DP 10.01, Falcon 3, Eastwest, NOVO Strings, 8Dio Brass, Spitfire,, Symphobia
Gravity Jim
Re: DP 9.5.1 is up.
Post by Gravity Jim »
KenNickels wrote:Re: 9.51 - Can anyone please confirm the following? Right-click MIDI editing still does not work in the Seq window, but works in the MIDI window. Last version working was 9.13. Since I do everything in the Seq window, this is a major inconvenience.
On my Mac, it doesn't do in the Sequence window on my Mac what it does in the MIDI window. In the Sequence window, right-click restrains the note to it's current time... it only allows pitch change without changing the note on position. In the MIDI window, it opens a mini-menu, which I assume is what you wish it would do.
Jim Bordner
KenNickels
Re: DP 9.5.1 is up.
OK, yes. But it used to work in the Sequence window is the point, going back to version 7, which is as long as I've been using DP. Why did they eliminate that functionality? It doesn't make sense.
Gravity Jim
Re: DP 9.5.1 is up.
KenNickels wrote:
That would be a good question to ask MOTU. How the heck would WE know? :lol:
Jim Bordner
KenNickels
Re: DP 9.5.1 is up.
Thanks, I just wanted to confirm the behavior, not the reason for it. MOTU confirmed that it is a bug, or rather, will put back that functionality. I thought it would have been done for 9.5.1 but no. What is telling though is that on this site no one has complained except me. Is no one using the sequence window for editing MIDI? :shock:
Gravity Jim
Re: DP 9.5.1 is up.
KenNickels wrote:Thanks, I just wanted to confirm the behavior, not the reason for it. MOTU confirmed that it is a bug, or rather, will put back that functionality. I thought it would have been done for 9.5.1 but no. What is telling though is that on this site no one has complained except me. Is no one using the sequence window for editing MIDI? :shock:
Not me. I always switch to the MIDI Window, and clean things up one track at a time. It keeps me from making dumb mistakes like leaving in ghastly mistakes... which I would hear LOUD AND CLEAR at mixdown.
Jim Bordner
monads
Re: DP 9.5.1 is up.
Post by monads »
Motu.com website is down and can't download the update!
http://www.OdysseyofaG.com
PPC G4 Dual 1.25, 2GB RAM, OSX 10.5.8, Lynx AES16, Duende Classic
Phil O
Post by Phil O »
Phil O wrote:There was an odd unexpected quit I'd get sometimes when opening a file (since v9) by double-clicking it in the Finder. Too early to tell, but I think it may be fixed. I worked all day yesterday in 9.51 and didn't see it.
Phil
I posted this 2 days ago. It's still working without any quits on my end. I think they fixed this bug.
Phil
Phil O
Re: DP 9.5.1 is up.
Post by Phil O »
I haven't installed yet on my older Mac Pro (1,1) - OS 10.6.8. Anyone know about compatibility with that beast?
Re: DP 9.5.1 is up.
Phil O wrote:I haven't installed yet on my older Mac Pro (1,1) - OS 10.6.8. Anyone know about compatibility with that beast?
Operating systems
Mac OS X version 10.6.8 or later
Windows 7 (32- and 64-bit)
Windows 8 (32- and 64-bit)
Windows 10
Processor
Mac or PC with Intel Core Duo CPU 1.83 GHz or faster
Multiple processors or a multi-core processor is required
RAM
2GB required
4GB or more recommended
Computer display resolution
1024 x 768 required
1280 x 1024 or higher recommended
64-bit operation
Available for Mac OS X 10.6.8 or later
Available for 64-bit versions of Windows 10, 8 and 7
Supported audio hardware
Mac: built-in audio, any Core Audio compatible hardware, any Core MIDI compatible hardware
Windows: any Windows 10, 8 or 7 Audio or ASIO compatible hardware, any Windows 10, 8 or 7 compatible MIDI hardware
Phil O
Re: DP 9.5.1 is up.
Post by Phil O »
Mike, as always you are very thorough. Thanks so much for your input here at Cornie Haven. If we haven't said it enough, your generosity is greatly appreciated. Where did you find this info? I looked in the 9.5 update notes and read me file to no avail.
Philippe
monads
Re: DP 9.5.1 is up.
Post by monads »
monads wrote:Motu.com website is down and can't download the update!
It's back up right now...downloading :headbang:
Re: DP 9.5.1 is up.
Just finished my first project in DP 9.5.1 and it's just fine here. No crackling at save while the transport is running or any other such nonsense. The performance meter (as usual) goes into the red when loading a VI or some other none CPU intensive activity. Seems to be when the process is done, like DP is sending an overload message when it re-cues the sequence. I've come to think of it as the idiot lights in my car. Just turning on the key will say you're overheated, your tires are flat, your brake is on, your oil is low, and your airbags aren't inflated. Then you start the engine and (hopefully) they all disappear and you're on your way.
I LOVE DP and MOTU. What an 'effing great app. We are soooo damn lucky to be alive when this thing is available.
Not a paid spokesperson for MOTU or MOTUNATION, but I did win a free Track 16 a few years ago at a MOTU event. LOL
2013 Mac Pro 32GB RAM
kwiz
Re: DP 9.5.1 is up.
Post by kwiz »
Amen!!
Great family and friends!
F. Douglas
