Dp control not working with 9.5?
tomf
Post by tomf »
It worked before I updated and now my iPad does not see the host. I need this to work!
Re: Dp control not working with 9.5?
Don’t update to iOS 11. DP Control is 32 bit, I believe.
tomf
Post by tomf »
It was working untill DP9.5
tomf
Post by tomf »
Thanks I got it to work.
dix
Post by dix »
mikehalloran wrote:Don’t update to iOS 11. DP Control is 32 bit, I believe.
Confirmed. DP Control does not work with OS11.
I have it working except switching to the Mixer page causes DP Control to force quit.
dix
Post by dix »
James Steele wrote:I have it working except switching to the Mixer page causes DP Control to force quit.
Really? I just get a "Needs to Be Updated". That's it. No option to launch.
I think I'm back on iOS 10.3.1. I get the "Needs to be Updated" warning, but then it lets me run it.
dix
Post by dix »
Ah. In iOS11 you'll get nada. It won't start at all. None of the old 32bit apps that gave that warning before will launch in this update.
I mentioned in the main thread on 9.5 that DP Control started working for me while it hadn't for a very long time. That includes the mixer (though I don't see a Master fader -- was that ever there in DP Control).
My assumption is that DP itself has changed to get it working better with OSC, least up to iOS9 which is where my iPhone 4S is stuck. It never worked at all with other DP9 versions.
My iPad is at 10.3.3, and DP Control launches on it and connects to DP. The track section works, and other functions like the mixer come up, but with these, DP Control will only mirror what DP does, and with a noticeable delay. It won't control DP.
Let's hope iOS 11 will trigger an update from MOTU.
