Lyrics
supersonic
Lyrics
Post by supersonic »
Hi
Do you know if it is possible to move an entire arrangement with lyrics in quickscribe? Here on 9.12, when I move notes by a couple of bars forwards the lyrics stay behind.
Music is movement in silence
Re: Lyrics
I don't use QS at all but just thinking out loud, what happens if you make the move(s) in the MIDI or tracks window? Do the lyrics make be with the notes?
buzzsmith
Re: Lyrics
Post by buzzsmith »
I don't use QS, either, for lyrics but I'm kinda thinking that the lyrics are not actually attached to the notes as in Finale.
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Re: Lyrics
What? So what's the point? That's just plain useless.
Re: Lyrics
I've only typed lyrics a couple of times in QS and the lyrics are locked to notes. I recall that the space bar jumped the text cursor to the next note, also a dash would do the same.
I'm not sure whether you can directly import/export lyrics, but with careful text editing, you can bring them in from even a text editor as long as the dashes & spaces cause things to shake out. YMMV
supersonic
Re: Lyrics
I read the manual in the End :D. You can reflow the lyrics. In my case I moved my music 4 bars forward, selected the first note and chose reflow from the lyrics window.
buzzsmith
Re: Lyrics
Post by buzzsmith »
supersonic wrote:I read the manual in the End :D. You can reflow the lyrics. In my case I moved my music 4 bars forward, selected the first note and chose reflow from the lyrics window.
I stand corrected and good to know!
Buzzy
Focal Twin6 Be(s)
