How to make automation off by default?
Hey everyone, I want to make automation for all tracks always default to off. No record enable, no play enable. I know there has to be a way to do this because DP used to, but I can't find it in prefs and there's no logical setting in the Automation Setup window that seems to work.
As it is now, I can create a "new" template that has them all turned off, and sometimes it will come up as a new document with them on anyway! In all cases, when I create a new track of any kind, it is automation record enabled by default. I want automation of all tracks to only be record or play enabled manually, per track, ever.
Re: How to make automation off by default?
I wonder if I should have posted this in the troubleshooting forum? I just don't see a way to do it in DP. Yet, I can't imagine that there is no way, it's pretty fundamental.. and it is the way DP used to operate, up until 9.
- buzzsmith
I'll look into this later today and see what my system does in this regard.
Are you creating your own template and then opening that one for each new project?
Buzzy
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Go to Setup/Automation Setup...
In the right hand pane, select a MIDI track in the topmost dropdown menu, uncheck "Enable Automation Playback" and "Enable Automation Recording", then click on the "Save as Default for MIDI tracks" button at the bottom of the right hand pane.
Then select an audio track in the topmost dropdown, and repeat the unchecking and click "Save as Default for Audio Tracks" button.
Mac Pro 'Nehalem' 2 x 2.66 Quad Core, 28GB, 10.11.6 || MacBook Pro 2.7 Intel Core i7 Retina, 16GB, 10.11.6 || MOTU 2408 Mk3, 828 Mk 2, MTP AV || DP 9.51 & 9.13, Mach 5 v3, MSI, Ethno2, MX4, VEPro6, all Spectrasonics, Kontakt ... and many of the other usual suspects.
http://www.thekeyboard.co.uk
Thanks David!
No probHCMarkus wrote:Thanks David!
Awesome David, thank you so much! Seems to work for instrument tracks too.. excellent!
Yeah, but it makes sense that the automation might turn itself on anyway, if the settings in Automation Setup are set to on by default..buzzsmith wrote:I'll look into this later today and see what my system does in this regard.
Buzzy
