Hello! newbie to the forum here!
I have a macbook running yosemite and an older iMac.
One has thunderbolt/usb and the other firewire/usb
Which of the older Motu's will/won't work/should I avoid?
Or will they all be ok?!
Bearing in mind I really want it to work with BOTH so a thunderbolt/firewire adapter will be needed.
Is there anything I should know??
Any help much appreciated
Thanks!!
Hello! which motu's will work with Yosemite please!
- buzzsmith
Re: Hello! which motu's will work with Yosemite please!
I *think* that the oldest one (assuming you might be looking on eBay) with Thunderbolt is the 828x.
http://motu.com/products/motuaudio/828x
Hope that helps!
Buzzy
Hope that helps!
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
What is it you want the interface to do? That would help us suggest models. I have an old 828mkII, and it worked fine under Yosemite with either FireWire or Thunderbolt (using an adapter and a hard drive that had FW800 and FW400 ports as a second adapter). Good for MIDI and ten channels of audio.
All Intel Macs are fine with USB.
Ok thank you!
So I want an interface with up to four audio inputs/line or mic.
The smaller the better for on location work.
MIDI is a bonus.
I have found an ultralite Mk1 which is a good solution?
Any help appreciated
MIDI is a bonus.
I still use an original 'Traveller' (mk I) and it's been fine through all the years up to my current El Capitan OSX. It's about 12 years old I guess.
It's got 4 audio/mic channels, and a myriad of other choices. Check out the specs, as it might serve you fine as it does me.
Works fine with a Firewire 400/800 adaptor. Never a problem.
DP 11, OS Ventura
MacMini 2023 M2Pro, 16 gig RAM, MOTU M6, SSD drives for everything, various sound/sampled libraries from all major vendors, Logic Pro X, DSP-Quattro
MacBook Pro 2015, OSX Monterey, 2.5ghz, 16 gig RAM (w/duplicate software as in MacMini setup)
Trombones: King 2B SilverSonic, King 2B Liberty, & Conn 88H w/Doug Elliott mouthpieces!
http://www.cammillarmusic.com
