How to stop Spectrasonics VIs volume jump
Posted: Wed Jan 25, 2017 1:58 am
by waterstrum
I know there is a workaround for this.
When I press play in DP 9.12 the volume slider in Spectrasonics plugs jumps to plus 10db.
I have turned off the automation etc.
I remember this was a bug or issue.
Thanks for reminding me how to fix it
Re: How to stop Spectrasonics VIs volume jump
Posted: Wed Jan 25, 2017 2:43 am
by HCMarkus
Put a volume event before the beginning of the track and enable automation.
Posted: Wed Jan 25, 2017 6:17 am
by funkyfreddy
Some of Arturia's VI's do this as well...... very annoying! I've almost had my head blown off from the volume a few times.....
Posted: Fri Jan 27, 2017 11:12 am
by magicd
Another solution: Disable Event Chasing for CC#7 and CC#10.
Dave
Posted: Fri Jan 27, 2017 1:33 pm
by Tobor
magicd wrote:Another solution: Disable Event Chasing for CC#7 and CC#10.
Dave
Ooh that sounds like a great solution. Thanks!
Just went through this....again....with Omni and Kontakt and was reminded to go to automation setup, check the 'only' box and leave it blank. Then set it as the default for all new tracks.
Not in DP at the moment so hope this is right.
Now to tie string around my finger to remember this when it happens again.....
Posted: Fri Jan 27, 2017 6:25 pm
by greg328
I just always enter a volume and pan command for every MIDI track so I don't get blasted! Spectrasonics VIs are SUPER HOT re: output level. I also turn down the virtual instrument automation volume level about -4 or 5db, to manage levels.
It's just become a habit.
Greg
Posted: Sat Jan 28, 2017 1:17 am
by waterstrum
Dave
Thanks for that solution.
I will try that.
Just to be sure...
If I add automation to those CC's... 7 and 10
Would that solution disable the automation chasing for those CC's?
So when I go to a new location in the sequence, those CC's won't be updated?
Posted: Sat Jan 28, 2017 8:53 am
by MIDI Life Crisis
It means that that last value set will be used until the sequence hits new cc data. Chasing is when the app looks for the last value used when locating to a new location and sets that value for playback. Unless I just don't know what I'm talking about. It happens!
