BWAV time stamps not lining up properly between DAW's
EMRR
Post by EMRR »
Anyone encountered this? I've not until recently, now it's twice in a month. In both cases the time stamps of imported files have been off by a second or two or 4. These are files recorded with merged and exported BWAV's from my sessions.
I have to wonder if it relates to this in any way, though it should be cured on my end due to the merge:
viewtopic.php?f=26&t=60120
Maybe it relates to a similar scheme in other DAW's?
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
buzzsmith
Re: BWAV time stamps not lining up properly between DAW's
Post by buzzsmith »
EMRR wrote:Anyone encountered this? I've not until recently, now it's twice in a month. In both cases the time stamps of imported files have been off by a second or two or 4. These are files recorded with merged and exported BWAV's from my sessions.
Yes.
One of my clients is PC based and using Cuebase. I have to send him WAV files, not BWAV so that they stay in sync with what he sends me.
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
EMRR
Post by EMRR »
Thanks. That's the second report I've received of BWAV versus WAV with Cubase. That seems entirely backwards from standards.
One of these was Cubase, the other was PT9.
Doug Williams
Tape Op issue 73
DP 11.34
EMRR
Post by EMRR »
How are you getting (non-B)WAV? Converting externally? I only see BWAV and AIFF as audio options in DP.
Doug Williams
Tape Op issue 73
DP 11.34
buzzsmith
Post by buzzsmith »
EMRR wrote:How are you getting (non-B)WAV? Converting externally? I only see BWAV and AIFF as audio options in DP.
No, within DP (9.01, in my case) in the Export options from the Soundbyte window.
A fairly long drop down list appears with Core Audio WAV as an option.
Hope that helps!
Buzzy
Focal Twin6 Be(s)
EMRR
Post by EMRR »
DP 8 only shows me BWAV and AIFF. I hadn't noticed SD2 had gone away.
Doug Williams
Tape Op issue 73
DP 11.34
mrgkeys
Post by mrgkeys »
I'm guessing you're right with the other thread. I've had this happen with BWAV files and for me the answer was Punchguard too. Changing it to "Only Record Pre Roll When Punching In" seems to fix it. No problems swapping BWAV files with any other DAW after that. It does make sense, where does the pre roll go if not in the file? And punching in is the only place I really want pre roll anyway. Never missed the start of something so far.. my motto is if the band is playing anything, we're recording.
YMMV
Michael
buzzsmith
Post by buzzsmith »
mrgkeys wrote:I'm guessing you're right with the other thread. I've had this happen with BWAV files and for me the answer was Punchguard too. Changing it to "Only Record Pre Roll When Punching In" seems to fix it. No problems swapping BWAV files with any other DAW after that. It does make sense, where does the pre roll go if not in the file? And punching in is the only place I really want pre roll anyway. Never missed the start of something so far.. my motto is if the band is playing anything, we're recording.
YMMV
Michael
I was wondering why one of my clients was having timing issues with files we were exchanging.
We ended up going with just the Core Audio WAV.
Buzzy
Focal Twin6 Be(s)
