I need MORE outputs - will an 828 do?
Questions! Questions!
Again I ask questions that likely have answers already covered in detail but where to look????
I'm looking for an inexpensive solution... I have an 828 Mk3 and I'm using it via Firewire in live shows with a MacBook Pro. Now I need more than the 4 pairs of outputs provided on the Mk3 as I want to route individual instruments to their own amp/speakers.
My question is this: Can any of the MOTU 828 Firewire models (the original 828, Mk1, or Mk2) be added to my existing set-up, via an optical cable, to provide an additional 4 pairs of audio outputs? And will CueMix FX also recognize the additional 4 stereo output pairs from the older unit along with those from my main 828 Mk3?
Considering I only need the additional outputs, would there be any advantage/disadvantage of using an 828, 828 mk1, or 828 mk2????
And if I wanted to expand MIDI outs it looks like I'd need to get an MIDI Express or something with USB — sound right?
Thanks Unicorns.
Ones of these days I'll be smart enough to offer help too.
But I'm learning.
BD
Thanks Unicorns.
But I'm learning.
BD
Re: I need MORE outputs - will an 828 do?
Why not hook up the second 828 via FireWire? You could make the two an aggregate device for audio and have another MIDI device built in. The mkII has CueMix.
I've used a MOTU 2408 with an 828-3 FW to get more ins and outs, so I'd suppose you can do the same with other MOTU units with ADAT. But I had to use separate instances of Cuemix to see both units but perhaps one instance of Cuemix will see more than one unit if they are the same model.
I also had to connect the units with wordclock. ADAT is supposed to carry clocking info, but I could never get it to work reliably.
Maybe an alternative is to get a cheap ADAT converter similar to the ADA8000 and connect it to the 828-3
Mikemikehalloran wrote:Why not hook up the second 828 via FireWire? You could make the two an aggregate device for audio and have another MIDI device built in. The mkII has CueMix.
I get the jest of your suggestion but not quite sure how to implement or am I overthinking it?
I really like the added MIDI I/O potential but "if" I understand what you are suggesting, don't I get—as bayswater suggested—two separate instances of CueMix?
So, is this what I do or am I missing something?
From the computer's FireWire 1 into 828 Mk3
From the computer's FireWire 2 into the 828 Mk2 (add on)?
OR daisy chain from computer's FW to 828 Mk3, on into Mk2?
I suppose, if that's the basic FW signal flow, either would work.
Are you sure the Mk2 has CueMix?
I thought it began with the Mk3 series.
(But once I establish a working system I seldom pay attention to new gear.
I seem to fall into a 4-5 year pattern of using a set up and then transition to the another set up. I do miss a lot that way.)
OR
Is there something ELSE I'm not aware of
Thanks, Mike.
You've been quick with good advise once again.
Thanks "bayswater" for the added input. I'll chew on that as well. Whatever I do I want to keep it simple.
- terrybritton
- Primary DAW OS: Windows
I have an Ultralite mk3 hybrid running via S/PDIF into my main interface, an 828 mk3 hybrid. I tried daisy-chaining them via Firewire but could not get reliable sync. This setup using the S/PDIF is working fine.
If you do daisy-chain the two (only possible via Firewire on a PC, possibly that is true on a Mac as well) you will have two separate Cuemix mixers. You will be able to switch a single open Cuemix mixer between the two via the "Devices" menu item. The MOTU Audio Console will also show a second device tab.
The Firewire daisy-chaining method may enjoy more stability in a Mac than I had experienced (running Firewire into a PC was flaky and I dropped doing it in favor of using USB).
The aggregation feature in Macs also gives you more possibilities, as the drivers to not need to be the same for the two boxes as is true in the case of daisy-chaining them via Firewire.
I hope that clarifies some things.
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
I think the best solution is to get an eight channel AD/DA that connects via ADAT Optical... Presonus and Focusrite both make such devices.
http://www.sweetwater.com/store/search. ... toPre+MkII
http://www.sweetwater.com/store/search. ... us+digimax
I've ben using a DigiMax with my 828mkII for years with nary a glitch. I clock via word clock, but you can also clock via the optical port. Big advantage is all inputs and outputs show up in one CueMix window. And no added latency.
- terrybritton
I really like that solution, HCMarkus!HCMarkus wrote:I think the best solution is to get an eight channel AD/DA that connects via ADAT Optical... Presonus and Focusrite both make such devices.
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Thanks to one and all.
I didn't imagine there were as many approaches to this issue that each of you have outlined.
For whatever reason it didn't occur to me to use gear outside MOTU - duh!
But now I can consider a wider range of solutions.
I suppose I'm somewhat typical in being reluctant to ask for "directions" but this time it sure paid off.
Thanks again.
BD
Thanks again.
BD
Alesis used to make an optical-to-analog A/D/D/A called the "AI-3". You may be able to find one somewhere used, and Black Lion Audio has a modification for it if you're tweaky. :
https://blacklionaudio.com/product/alesis-ai3/
But if you're only looking for outputs, Aphex has a good unit:
http://aphex.com/products/141b
We've been using one at our studio to get extra headphone mixes from an Avid 96 interface for years, no problems.
MacBook Pro 9,1 (mid-2012 Core i7 2.3 GHz 4 GB RAM), OSX 10.11.3, Newertech Voyager SATA drive dock
MOTU: DP 9.02, Traveler Mk 1, 896 MkIII Hybrid, MIDI Express XT
Alesis AI3 optical interface, QS8, QS7, DM Pro, DM5, QSR
Mackie Controller and Extender (original MIDI)
Pro Tools 12
Pro Tools 12
And just when I thought all the options had been suggested.TinenTech wrote:Alesis used to make an optical-to-analog A/D/D/A called the "AI-3". You may be able to find one somewhere used, and Black Lion Audio has a modification for it if you're tweaky. :
Thanks, TinenTech for the added input... I'll look into it as well.
Have a great T-Day!
