VST rack that has parallel signal path?
Hi I was wondering if there is something similar in DP to the Audio effects rack that you get in Abelton live? So that you can have VST effects split the signal and working in parallel?
Re: VST rack that has parallel signal path?
I don't understand the need. Why wouldn't you just use multiple instances of a VST? With a few exceptions, the Mac OS and DP handle that very well.
If you need to process a signal in multiple parallel paths, just use sends, busses and aux channels to set up any routing you might want other than a feedback loop.
