Is there a way to record the output of one of the 8 mixbusses in cuemix?Cant find anythimg but the hardware inputs in cubase 7.5 connections.Is there a way to route this in cuemix?
Daw used
Win 7 64
Cubasd 7.5
Motu 828 mk3 hybrid
Regards Nils
Record one of the Cuemixes in Cubase?
- Primary DAW OS: Windows
- terrybritton
Re: Record one of the Cuemixes in Cubase?
Nils,Majshumlan wrote:Is there a way to record the output of one of the 8 mixbusses in cuemix?Cant find anythimg but the hardware inputs in cubase 7.5 connections.Is there a way to route this in cuemix?
Daw used
Win 7 64
Cubasd 7.5
Motu 828 mk3 hybrid
Regards Nils
It is set up in the MOTU Audio Console on the 828 tab.
Click the drop-down next to the word "Return" and it will show not only the hardware outputs you can send to the DAW, but the 8 mixes as well. Select the one mix you want sent to the DAW (Mix 1-8) assigning that output to the "Return" bus, then in the DAW select the Return channel as the signal source, and you will get that mix.
Let me know if you need any more information.
BTW - the DAW will also show a "Reverb" channel that is a feed from the global reverb within the 828.
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Aha great!!
Should not be any problem!
Thanx!!!
Thanx!!!
