V-Rack Sends
Rusty Shackleford
V-Rack Sends
Post by Rusty Shackleford »
Is there a way to increase the number of sends on a V-Rack Track to at least 4? Thanks!
iMac 20,1 10-core, 3.6Ghz, OS10.15.7, 128GB RAM, DP 10.13, VEP7
Re: V-Rack Sends
In the mixer, use the mini menu in the upper right to show the V-Rack. When it shows in the mixer window, use the mini menu again and select the option to set the number of sends.
Rusty Shackleford
Re: V-Rack Sends
bayswater wrote:In the mixer, use the mini menu in the upper right to show the V-Rack. When it shows in the mixer window, use the mini menu again and select the option to set the number of sends.
Ah... I had both the V-Rack and the rest of the tracks showing in the Mixer window which was the problem. Thanks, bayswater!
Re: V-Rack Sends
Yes, it threw me too -- why the V-Racks were all different and different from the main sequence, but I suppose the principle is that they are all separate Chunks, so you can look at them all at the same time, but you can't edit them all at the same time.
Re: V-Rack Sends
Yeah, they are like linked chunks that display in the Mixer by request, but aren't native to that chunk. You can also just double click on the V-Rack chunk and go directly to it, I think.
Rusty Shackleford
Re: V-Rack Sends
Thanks for the replies
