In what way can I use the IAC Driver with DP?
Tomas E
Post by Tomas E »
Up until now I haven't been at all interested in the IAC Driver and what it does. I watched some movie on YT but that didn't bring me any closer to an answer. Selecting it in the output and rec enable the track is not possible since it will create a playback loop. It should be of some use since it's a selectable output device. Or is it not?
Re: In what way can I use the IAC Driver with DP?
I've used IAC to host VIs in DP and use them in Finale. That's about it for me.
cleamon
Post by cleamon »
I use IAC to send MIDI to MainStage/Logic VIs from DP. I then use SoundFlower to route the audio back into DP.
Chuck
iMac (Retina 4K, 21.5-inch, 2017)|| 16GB Ram || OS/X 10.14.6 || Motu 828MkII || Steinberg UR242 || DP8.07
Macbook Pro (Retina, 13-inch), 2.7 GHz i5, 8GB Ram
It does pretty much the same thing as DP's Interapplication MIDI. You can look that up in the manual. It appears on the Mac as another standard MIDI device and will do the same.
Tomas E
Post by Tomas E »
MIDI Life Crisis wrote:I've used IAC to host VIs in DP and use them in Finale. That's about it for me.
Are you saying that by using the IAC it's possible to have DP with all its VIs, mixer settings and effects playing back a Finale file?
Tomas E
Post by Tomas E »
bayswater wrote:It does pretty much the same thing as DP's Interapplication MIDI. You can look that up in the manual. It appears on the Mac as another standard MIDI device and will do the same.
Ok, thanks. I only looked for IAC in the manual and didn't find anything.
