Warning- Toontracks 2.1.3 BREAKS in VE Pro
- toodamnhip
Installing Toontrack EZ drummer 2.1.2 or 2.1.3 will cause Ve Pro files containing EZ drummer to NOT be able to open previously created EZ drummer sessions. For old sessions files, (meaning less files made 2 weeks ago or earlier), The last working version of EZ drummer and toontracks is version 2.0.2 or maybe 2.1.1 I am not sure which.
Again, installing versions 2.1.2 and 2.1.3 will result in Ve Pro not being able to open older EZ drummer projects. You will NOT be able to go back to EZ drummer 2.1.1 as far as I can tell. And, Toontracks has NOT been able to fix this for a week. All efforts to get me back to 2.1.1 or 2.0.2 have failed. VE Pro is also working on a fix. As of right now, I cannot get to my past VE Pro toontrack sessions and they are broken until Vienna or Toontracks comes up with a fix. DO NOT UPDATE Toontracks EZ drummer past 2.1.1 VE Pro will open fine, but will give error messages on the old EZ drummer instantiations. Vienna has informed me this is possibly due to Toontrack changing their protocol for naming EZ drummer instances/
This means, DO NOT use the new Toontrack product manager as it will recommend you update, and your old less files in VE Pro will break.
If you have NO older EZ drummer sess files and update to the latest version of EZ drummer inside of VE Pro , you will be able to make new EZ drums without issue. This only effects previous less files made in VE Pro.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- zuul-studios
Re: Warning- Toontracks 2.1.3 BREAKS in VE Pro
Does this hold true for Superior Drummer, too?!?
Computer:
Apple's M2 Mac Studio with 96 RAM; macOS X 14.5 (beta 3); 1 Internal SSD, 8 External SSDs, MOTU 828es audio device, AKAI MPK88 Keyboard Controller
Software:
DP11.31, Logic Pro X, FCPX, DaVinci Resolve; VSL's Super Package, VEPro 7 & MIR Pro, VI Pro 2; Altiverb 8; Cinesample's CineSympnony Complete Bundle; Native-Instrument's Komplete 13 Ultimate Collectors Edition, and many more VIs.
Software:
- Guitar Gaz
It must only affect VE Pro users - both Toontrack EZDrummer2 and Superior Drummer work fine with DP and El Capitan. This must be a VE Pro issue rather than a Toontrack or DP issue I presume.
Gary Shepherd
____________
____________
- toodamnhip
Well, when you say VE Pro issue, it depends on how you look at things. Toontrack CHANGED something. It broke in VE Pro. Who’s fault?.....Guitar Gaz wrote:It must only affect VE Pro users - both Toontrack EZDrummer2 and Superior Drummer work fine with DP and El Capitan. This must be a VE Pro issue rather than a Toontrack or DP issue I presume.
I do not know if it effects superior.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- Guitar Gaz
I can only say what I have found - I don't actually understand how you use it with VE Pro that could break it - I use EZDrummer2 and Superior Drummer as a sound source in V racks and drag the MIDI files to a track in DP and use the EZDrummer2 and Superior Drummer kits for the sounds. It doesn't affect any other of my sound sources (such as Reason, Wavestation or M1 VI's). So I am puzzled as not much has changed with the Toontrack updates as far as I can see with functionality. Someone at Toontrack should look into this - best of luck with this and interested to hear of any solutions.toodamnhip wrote: Well, when you say VE Pro issue, it depends on how you look at things. Toontrack CHANGED something. It broke in VE Pro. Who’s fault?.....
Gary Shepherd
____________
____________
Toontrack products are working for me. Not having VE Pro, whose issue this is . . . well, it's not mine.Guitar Gaz wrote:It must only affect VE Pro users - both Toontrack EZDrummer2 and Superior Drummer work fine with DP and El Capitan. This must be a VE Pro issue rather than a Toontrack or DP issue I presume.
- toodamnhip
VE Pro became a necessity when it was found to be at least 50% more efficient than running VIs in DP. Hopefully, the next update will eliminate the need for 3rd party programs such as this. But to anyone seemingly confused as to why I use it, there is your answer.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- Guitar Gaz
I understand - I wasn't aware of VE Pro as a plug in host. What happens if you just run EZDrummer2 in DP as a V rack and don't run it through VE Pro? One plug in in DP's V rack like EZDrummer2 may not be as efficient for your purposes but presumably you could use VE Pro for other plug ins? Does VE Pro work then?toodamnhip wrote:VE Pro became a necessity when it was found to be at least 50% more efficient than running VIs in DP. Hopefully, the next update will eliminate the need for 3rd party programs such as this. But to anyone seemingly confused as to why I use it, there is your answer.
Gary Shepherd
____________
____________
- toodamnhip
The problem is, the set up of the drums is stored with VE Pro.Guitar Gaz wrote:I understand - I wasn't aware of VE Pro as a plug in host. What happens if you just run EZDrummer2 in DP as a V rack and don't run it through VE Pro? One plug in in DP's V rack like EZDrummer2 may not be as efficient for your purposes but presumably you could use VE Pro for other plug ins? Does VE Pro work then?toodamnhip wrote:VE Pro became a necessity when it was found to be at least 50% more efficient than running VIs in DP. Hopefully, the next update will eliminate the need for 3rd party programs such as this. But to anyone seemingly confused as to why I use it, there is your answer.
I didn;t save the EZ drummer as a pre set.
Its always been a bit confusing to me as to how to store EVERYTHING in an EZ drummer pre set. And, I did;t think it necessary. Now, I know I need to in the future.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
