MACH 5 FREEZE
Posted: Fri Feb 11, 2005 1:43 pm
by XXF
I recently installed Mach 5 on a new G5. Now as I tool around on it, sliders freeze and when you click on the notes in the sample editor they don't disengage. ANy suggestions to get rid of this freezing problem? Restarting the computer doesn't help.
Re: MACH 5 FREEZE
Posted: Fri Feb 11, 2005 4:45 pm
by thracks
Does this happen after you drag samples into Mach 5 from the finder? If so, de-select the samples in the finder or close the finder window completely after dragging samples in.
Re: MACH 5 FREEZE
Posted: Tue Feb 15, 2005 3:34 pm
by XXF
That worked. Thanks!
