Motu 8 pre connection problem
andrea.araf
Post by andrea.araf »
Hi guys, my first post here.
I got a problem!
Some months ago i got a Motu 8 Pre Firewire and loved it.
Now i had to change my PC. My new laptop has NOT a firewire port.
It only has 3 USB ports and 1 HDMI port.
Is there any chance to connect Motu 8 pre to it?
I know there exists Firewire-USB and Firewire-HDMI converters; don't know if they'll work with Motu. I've read that Firewire-USB only works if the Firewire device is "USB Aware", which i don't know for the motu.
Thank you very much
Andrea
Re: Motu 8 pre connection problem
The 8pre requires a direct FW connection according to posts that MOTU made a number of years ago. It's not even supposed to work with the Apple Thunderbolt-FW converter although there are posts here from people who were successful in that regards.
So, will it work with an HDMI-FW adapter? Probably not but, if you can make it happen, post here and let others know.
Can you buy a FW card that works with your laptop? If so, get one that uses the TI chip for best results.
andrea.araf
mikehalloran wrote:The 8pre requires a direct FW connection according to posts that MOTU made a number of years ago. It's not even supposed to work with the Apple Thunderbolt-FW converter although there are posts here from people who were successful in that regards.
Hi Mike,
I couldn't find a Firewire-USB adapter in 4 shops in my town today. I'll take a try to the HDMI-FW if i'll find it.
Sadly i can't buy a FW card for my laptop.. it has not the slot.
But don't you think i'll have problems with the drivers/software part if i connect the Motu to an adapter?
Thank you very much
a
Yes, I believe that you will have problems and there's little chance of success. You are on Windows which lessens the odds.
So, if you can find the adapter and it's a store that lets you return, you might want to try. Otherwise, I believe that you are in the market for a new interface.
andrea.araf
mikehalloran wrote:Yes, I believe that you will have problems and there's little chance of success. You are on Windows which lessens the odds.
Thank you Mike.
Let's see.
I'm already in the market 'cause i want to buy a UAD Apollo twin duo usb; so i'll link them two via ADAT. I just wanted to be able to use the Motu until i'd buy the Apollo.
Bye
A
andrea.araf
Thank you Mike.
Let's see.
Bye
A
