Better Snap Tool...
Posted: Tue Apr 19, 2016 9:48 pm
by MIDI Life Crisis
Just bought this from the makers of Better Touch Tool. Cool app for $3, but doesn't play well at all with DP. I'm loosing menu bars and the movement of windows with BSTool is unpredictable.
Anyone else try this app yet?
Re: Better Snap Tool...
Posted: Tue Apr 19, 2016 9:56 pm
by mikehalloran
Posted: Tue Apr 19, 2016 10:34 pm
by MIDI Life Crisis
It is. Frankly, with three monitors and not having them on all the time, it sometimes is a problem if a window opens in a powered down monitor. With this app, you can created a key command to cycle the window thru monitors. That alone is well worth $3, IMO.
I'll be playing around with this but it's already changed my workflow a bit, as has their sister app, Better Touch Tool.
Thanks for answering, Mikey!
Posted: Tue Apr 19, 2016 11:06 pm
by cuttime
I'm confused. I thought that BST is now incorporated in BTT:
https://www.boastr.net/merging-bettersn ... -into-btt/
I haven't tried the BST in DP yet. I'm on v.1.66 of BTT. You use this with Consolidated Windows? How?
Posted: Wed Apr 20, 2016 12:08 am
by MIDI Life Crisis
I float some windows out of the CW, like the mixer and meter bridge. I like the control but sometimes DP just screws up the CW when I'm applying BSTool to the mixer. Weird. I still have some learning to do. I didn't know the two apps were combined. Don't mind the $3 and happy to support good work.
Posted: Wed Apr 20, 2016 6:14 am
by mikehalloran
The two apps aren't fully combined yet but will be. It's a little confusing.
Anyway, I use three monitors also. I'm going to check this out. Thanks for the heads up.
Posted: Wed Apr 20, 2016 1:05 pm
by cuttime
The window snapping in BTT seems to be fully implemented except for multi monitor use. With my initial tests, some windows work correctly and some don't--notably the mixer, but I'm not really sure what I'm doing:
https://www.boastr.net/bettertouchtool-snap-areas/
Posted: Wed Apr 20, 2016 1:40 pm
by MIDI Life Crisis
Thanks. That validates me purchase as I'm using three monitors and find the app
extremely useful in that regard. I'm liking it, a lot, and in conjunction with BTouchTool and the Magic Trackpad 2, I'm navigating and editing much faster than I did with my little mousies...
