DP 9 Demo/Surface Pro 3
Posted: Sun Oct 11, 2015 2:39 pm
by FunkyBearMusic
I'm a former DP user from the mac world and I'm trying out the DP 9 demo on a Surface Pro 3 running Windows 10. (8 gigs of ram, 256 internal drive, i5)
Right now I'm getting HUGE (like half a second) latency from playing the USB keyboard to the sounding of the note in the synth plug ins. (Used MX4 and Model 12 I think - drum sounds)
Processor is set to 80% right now, the default from the install. Automatic Plug in latency is turned on.
Any suggestions or is this where things are right now with Windows 10 and DP?
Re: DP 9 Demo/Surface Pro 3
Posted: Sun Oct 11, 2015 4:16 pm
by kdm
If you are running Windows audio driver, the default is 2048 samples on the Surface Pro 3 (it is here at least). That's way too much latency for playing VIs. I couldn't get DP to work with ASIO4All, but that's still running off of the internal audio hardware. You might have better success with a USB audio interface (probably have to use a hub for the keyboard and interface).
Posted: Mon Oct 12, 2015 12:29 pm
by FunkyBearMusic
Is there no way to change the 2048 buffer? I haven't been able to find any place to do it. The button in the Consolidated Controls doesn't do anything and I don't see it in the location it was on the Mac. I searched the online help but couldn't find an answer.
Posted: Mon Oct 12, 2015 1:36 pm
by kdm
I haven't found a way, even in device properties. I believe it is using the WASAPI driver, and there may not be a buffer setting.
ASIO4All will work, but not through the built-in speakers - any other driver requires a separate USB interface.
